914 /6 clutch, clutch release point |
tom9146 |
Dec 10 2006, 12:47 PM
Member Group: Members Posts: 54 Joined: 22-December 05 From: Ottawa Canada Member No.: 5,307 |
Just wondered if anyone has had this problem before ...
when cold clutch releases fine adjusted with 1" pedal play.. after engine up to temp cluth releases higher and will chatter easily any thoughts ? |
Dr. Roger |
Dec 10 2006, 01:04 PM
when's the last time you looked at your clutch plate and pressure plate?
tom9146 |
Dec 10 2006, 01:16 PM
when's the last time you looked at your clutch plate and pressure plate? Haven't looked yet I was hopeing this was not the problem , also the clutch does not slip ... yet maybe its on the edge , the strange part is if everything is cold clutch goes back to normal operation !! |
Lo-Fi Version | Time is now: 18th May 2024 - 08:59 PM |
