Just wondered if anyone has had this problem before ...
when cold clutch releases fine adjusted with 1" pedal play.. after engine up to temp cluth releases higher and will chatter easily
any thoughts ?
Dr. Roger
Dec 10 2006, 01:04 PM
when's the last time you looked at your clutch plate and pressure plate?
tom9146
Dec 10 2006, 01:16 PM
QUOTE(Dr. Roger @ Dec 10 2006, 11:04 AM)
Haven't looked yet I was hopeing this was not the problem , also the clutch does not slip ... yet maybe its on the edge , the strange part is if everything is cold
clutch goes back to normal operation !!
