Alt methods to open engine lid |
GaroldShaffer |
Nov 14 2003, 10:15 PM
You bought another 914? Group: Benefactors Posts: 7,621 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
How can you open the engine lid when the cable is broken
and/or stuck?? (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) This is on the parts car, I don't care about the lid but I would like to not damage the grill if possible. Garold PS how about a smiley using a sawzall??? |
Nov 14 2003, 10:18 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
cut around the lock from the rear trunk. then the lid should come open with the lock still attached to it ...
Andy |
Slowpoke |
Nov 15 2003, 09:55 AM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
Drill out the bolts holding the latch mechanism to the trunk partition. You can access the bolts from the trunk side. Everyone owns a drill. Then clip the wire retaining the latch pull cable. Sounds easy (IMG:style_emoticons/default/laugh.gif)
Peter |
GWN7 |
Nov 15 2003, 10:21 AM
You also might be able to trip the lock from the top with a thin screwdriver. You have to come in from an angle to catch the lock dogs and push them open.
JFJ914 |
Nov 15 2003, 10:54 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Pop out the plastic cup and feel around?
Aaron Cox |
Nov 15 2003, 10:59 AM
what if you just cut the bolt that goes into the latch.
URY914 |
Nov 15 2003, 11:32 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,466 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
1.Jack up the car
2. Pull the engine out. 3. Fix the latch |
tracks914 |
Nov 15 2003, 11:35 AM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Take the seats and back pad out.
Cut a 18 inch hole in the fire wall. Crawl in and fix the latch. (IMG:style_emoticons/default/blink.gif) |
boxstr |
Nov 15 2003, 11:55 AM
For any of the above, DISCONNECT THE BATTERY!!
CCLINHELPSVILLE |
Lo-Fi Version | Time is now: 9th May 2024 - 11:23 AM |
