How can you open the engine lid when the cable is broken and/or stuck??
This is on the parts car, I don't care about the lid but I would like to not damage the grill if possible.
Garold
PS how about a smiley using a sawzall???
Nov 14 2003, 10:18 PM
cut around the lock from the rear trunk. then the lid should come open with the lock still attached to it ...
Andy
Slowpoke
Nov 15 2003, 09:55 AM
Drill out the bolts holding the latch mechanism to the trunk partition. You can access the bolts from the trunk side. Everyone owns a drill. Then clip the wire retaining the latch pull cable. Sounds easy Peter
GWN7
Nov 15 2003, 10:21 AM
You also might be able to trip the lock from the top with a thin screwdriver. You have to come in from an angle to catch the lock dogs and push them open.
JFJ914
Nov 15 2003, 10:54 AM
Pop out the plastic cup and feel around?
Aaron Cox
Nov 15 2003, 10:59 AM
what if you just cut the bolt that goes into the latch.
URY914
Nov 15 2003, 11:32 AM
1.Jack up the car 2. Pull the engine out. 3. Fix the latch
tracks914
Nov 15 2003, 11:35 AM
Take the seats and back pad out. Cut a 18 inch hole in the fire wall. Crawl in and fix the latch.
boxstr
Nov 15 2003, 11:55 AM
For any of the above, DISCONNECT THE BATTERY!! CCLINHELPSVILLE
