What type of carbs are these?, I've used them to bench test an old engine... |
ptravnic |
Dec 12 2006, 06:58 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Any ideas? I know they're Solex - anyone used these successfully?
I'd like to use them just to get the car moving under it's own power... |
Dec 12 2006, 07:14 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Well, they say "SOLEX" on them--clearly visible on the right side of that second picture. What does it say under that? I can't make it out... If you can read that, you'll have a pretty good idea of what size/config Solex it is.
At a guess: 36 PDSIT (Bus carbs) or 40 PDSIT (Type IV or European 1.8 914 carbs). That's a real wild guess, though, because I've never seen those in person. They are, however, single-throat Solexes, just like the two I mentioned were... --DD |
ClayPerrine |
Dec 12 2006, 07:30 PM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have seen a set of Bus carbs in person... and they are a POS... Ask Cap'n Crusty about them...
The throttle shafts wear badly and then they wont' run for shit.... I would look at FI or a set of Webers before running these. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:32 AM |
