Transaxles for high torque |
LS6/914 |
Nov 15 2003, 09:49 PM
Never leaves the shop member Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest |
Hey gang I need info on shops that can perform ring gear flip for 915 & 930 transaxles. The cylinder heads that I have recently installed took the output well beyond the trans in the car now(gear oil looks like chunky soup) The beast is at the body shop getting flares & paint so its time to step up. Thanks in advance, Lar
r_towle |
Nov 15 2003, 10:10 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Mueller |
Nov 15 2003, 10:47 PM
I don't see anything on thier web site that remotely hints that they do the 930 gear box modifications.
You want a shop that has done them before. |
SirAndy |
Nov 15 2003, 11:15 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
ask Brad-Meister at the All914 shop ...
http://www.all914.com/ tell him i sent you (IMG:style_emoticons/default/laugh.gif) Andy |
Britain Smith |
Nov 16 2003, 03:30 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Well...this is actually two totally different issues here. A 915 tranny is much easier and cheaper to flip than a 930. To get an idea of where to get the work done, you must specify which tranny you are going to use and for what application. Anything can be done, just brings wads of cash.
-Britain |
LS6/914 |
Nov 16 2003, 03:29 PM
Here is more info on the project. Previous had a 327. Now is a stroked 350 with Lingenfelter aluminum heads. I believe a 930 would be the best long term solution...
Attached thumbnail(s) |
Brad Roberts |
Nov 16 2003, 03:35 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I have all the jigs/fixtures to flip the 930 Ring gear. The biggest issue with the 930 is lack of decent shift linkage. The cable setups "work". The solid linkage solutions make the shifter do funny things in your hands (the shifter makes an arc when shifting from 1-2)
The 930 tranny is the best solution. We just dont have a good shift solution right now. Wevo has hinted at making a 930 shift solution (which would end all issues with shifting the 930 box in a mid-engine config). They already have the industry standard for the 915 in a mid-engine config. When will you work on the LS6-into a 914 project ?? B |
LS6/914 |
Nov 16 2003, 03:57 PM
B, the LS6 is waiting for more input (read that CASH). Can you facilitate the work on the 930? Iam also looking at a possible mate of the ls to the vette transaxle, however our shop has not had one long enough to actually dissassemble & measure(GM frowns on my habit of taking things apart under warranty)
BIGKAT_83 |
Nov 16 2003, 04:57 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Looks kinda long to me.
Bob Attached image(s) |
smrz914 |
Nov 16 2003, 05:30 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
the best choice is a 930. I want one but can't afford it. Anyways, You can talk to Renegade about a cable shift kit. LastI checke they wanted $650 for the shifter. www.renegadehybrids.com might have some info or better yet call them.
BIGKAT_83 |
Nov 16 2003, 05:43 PM
LS6/914 lets see some pictures...
Been in the planning stages for a LS1/LS6 914 swap for a few months now. I have just finished with a 914/383 sbc swap and ready to try the LS6. I've had a LS1 and a SBC side by side in the garage and measured both for size and see no reason that the LS1 should not be a great fit with the throttle body facing the rear as shown in the picture I just posted. Plan to buy a LS1/LS6 over the Thanksgiving weekend at the big swap meet in Daytona. Bob (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 06:07 AM |
