Project Turbo 914 begins..., (yes, I know you can't turbo a 914) |
ottox914 |
Dec 24 2006, 01:44 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Just a little teaser on this winters project. Last winter I dug into this little update:
http://www.914world.com/bbs2/index.php?sho...c=53733&hl= This winter will be phase 2. This photo will show some of the goodies under the tree, which will soon be under/on the car. The WRX intercooler has one round inlet on the back, and 2 smaller oval outlets under the opposite end tank. These will each exit and attach to some CB performance turbo "hats" for the ITB's that have 2" tubes welded to them. Some silicone elbows, and we're good. The intercooler will mount on braces running across the engine bay to support the intercooler as close to the GT lid as possible. I'll see how it goes, and probably do some yarn tuft testing to see about airflow in and around that lid, but I could always use the SDS computer to switch on either a puller or pusher fan below the intercooler based on boost, if needed. The turbo will mount on a custom flange/adaptor to be built to connect the turbo to the collector of the Kerry Hunter exhaust system. The turbo is a small Garrett VNT. The compressor map looks like a good match for this motor. I'm expecting the VNT turbo to give good low rpm thorttle response. Starting out at 5-6 psi, I'd be happy to see 10 when I'm done, but will tune to run safely on 93 pump gas and see where we end up. Off the back of the transmission, where the factory exhaust hanger mounted, I'll mount a similar hanger to support the turbo and exhaust system. A Tildon differential pump will return the oil to a willing valve cover. Oil will be taken from a "T" at the pressure sending unit on the case. There is a blow off valve to be added to the intercooler, and a mocal thermostat/sandwitch plate adaptor for the oil cooler, which has a thermostat controlled fan. I'll be adding an ignition switched relay for power to the fan and scavenge pump, so both will have power when the key is on. The pump will run continously, the fan when the thermo switch tells it to. Add some pressure side stainless or aluminum tubing from the turbo, thru the back engine tin, into the round inlet on the intercooler and we're done. Except for another trip to the LSE dyno, for some additional tuning. I'll keep posting as progress would warrent. Attached image(s) |
ottox914 |
Sep 1 2007, 11:04 PM
Now for some good stuff. Got all the piping roughed in for the left ITB. It just needs some beads added to the ends to keep the hose on, and its done. The rt side needs an extention welded onto the "J" shapped piece, as the piece is about an inch to short on the short end of the "J". Ron will be heli-arcing that tomorrow with stainless, so the joint should be pretty invisible. This winter it all comes appart for powder coating anyway.
The last pic is the intercooler and piping. Keep in mind we need to add a little length to the pipe on the left as it turns back to the ITB, add beads, and bolt it all togather for good. I also spent some time checking the turbo and actuator, to make sure the vanes were working as expected. All checked out good, and I got it adjusted to work for this application. To be done: finish the turbo exhaust flanges, make the header collector adaptor, mount the scavenge pump, wire it, add oil in/out, make a short exhaust pipe, lengthen the wide band wired to get the sensor further back, add a bung for the Os sensor in the exhaust pipe, add piping from the turbo to the intercooler, install the turbo tach. Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:50 PM |
