914 low profile tires |
chcjr |
Dec 28 2006, 08:51 PM
Newbie Group: Members Posts: 5 Joined: 20-October 06 From: Raleigh, NC Member No.: 7,067 |
What must be done to use low profile tires on a 1975 1.8 liter 914?
Thanks |
hwgunner |
Dec 28 2006, 09:01 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
First thing is to buy them. Second is to mount them.....
Sorry, sort of in a WA mood. What size do you want to go. 205/50 or 195/50??? If you want to use 205's you need to make sure that the wheels you have on your car are Original Porsche wheels or, if aftermarket, the Porsche offset. Lots of wheels out there that look Porsche but are not and they may have the VW offset which means the outside of the rim sits to close to the outer edge of the fenderwell thus causing rubbing issues. Even with Porsche wheels you may have to "Roll" the fender lip. If you want 195's then my info says go for it and you will not have rubbing issues but lets see what some one else says about that. Also if you stick with 15 inch wheels and go low profile your speedo will be off by a fair amount. This can be fixed by North Hollywood Speedo or Palo Alto Speedo for the right amount of green. |
Gint |
Dec 28 2006, 11:24 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Im going to move this thread to the garage for you. You'll get a much better response to your query in there.
McMark |
Dec 29 2006, 12:44 AM
205/50's fit on most cars. Here's is Nathan's ex-car. Pretty sure these are 205/50s.
I can't wait for Hoopa 2007 Attached image(s) |
DanT |
Dec 29 2006, 12:50 AM
205x50x15 on 5.5 inch rims with 1/2" spacers on the rear and 3/4" spacers on the front.
DanT |
Dec 29 2006, 12:55 AM
1970 1.7L with 205x50x15 on 5.5 rims no spacers
Dr. Roger |
Dec 29 2006, 01:06 AM
and just in case you haven't seen our tire calculator....
http://www.914world.com/specs/tirecalc.php =-) Roger |
Mueller |
Dec 29 2006, 01:14 AM
i was running 205/40s on 16s and then 205/40 on 17s, no mods needed at all with the correct rim
914werke |
Dec 29 2006, 01:32 AM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
The Tire calc is interesting but not usefull determining if a given choice will
fit under your fenders.. 205 is the generaly accepted MAX width that will fit under stock, non-rolled fenders. But evan that can depend on the tire manufacture and the build variances in your chassis. 215's will sometimes work but the manufacture selection seems to be small, 225's tend to be the absolute outside limit with narrow bodies, with or w/o rolled fenders (IMG:style_emoticons/default/smile.gif) I was at Discount today installing some rubber on my Avant and just about picked up a set of Yoko AVS ES100's in 225x45x16 ...on Fuchs..but they WILL be going on a mildly flared car (ala John Kelly) (IMG:style_emoticons/default/piratenanner.gif) |
John Kelly |
Dec 29 2006, 03:37 AM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
Hi Rich,
I was hoping to hear something about the the mild flares soon! When do we get to see pictures? John www.ghiaspecialties.com |
Hammy |
Dec 29 2006, 03:47 AM
I really like the look of low profiles on 914's.
Anyone know how low profiles look on western rims? Sorry for the slight hijack. |
Joe Bob |
Dec 29 2006, 08:29 AM
Never seen lo pros on Westerns....but lo sidewalls can cause high revs on the freeways, throw off the speedo, lower top speed and higher oil temps....BUT, they look good, give you better out of the hole performance (trailer trash re-gearing) and better grip.....choose yer poison.
Mueller |
Dec 29 2006, 09:28 AM
The Tire calc is interesting but not usefull determining if a given choice will fit under your fenders.. 205 is the generaly accepted MAX width that will fit under stock, non-rolled fenders. But evan that can depend on the tire manufacture and the build variances in your chassis. 215's will sometimes work but the manufacture selection seems to be small, 225's tend to be the absolute outside limit with narrow bodies, with or w/o rolled fenders (IMG:style_emoticons/default/smile.gif) I was at Discount today installing some rubber on my Avant and just about picked up a set of Yoko AVS ES100's in 225x45x16 ...on Fuchs..but they WILL be going on a mildly flared car (ala John Kelly) (IMG:style_emoticons/default/piratenanner.gif) low profile tires have more in common with diameter than width, he needs to be more specific with the question...like diameter of the rim would be important (IMG:style_emoticons/default/biggrin.gif) |
Marv's3.6six |
Dec 29 2006, 10:08 AM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
IMO you need plus sized wheels to get it right.
plus 1" over stock: Blue car 205/45/16 Fuchs 7" plus 2" over stock: Silver car 215/45/17 HRE311 8" Attached thumbnail(s) |
shmark |
Dec 29 2006, 11:53 AM
Spy Group: Members Posts: 16 Joined: 5-August 03 From: Marietta, GA Member No.: 985 |
225/45, no spacer in front, 1/4" spacer in rear works great on non-rolled fenders. Well as long as the tires are Hoosier bias-plies. (IMG:style_emoticons/default/biggrin.gif) Radial tires require rolling and maybe a larger spacer, but if you're determined 225 will fit.
I ran 195/50 on Fuchs, Empis and a few others with no issues other that a speedo/odo that was waaaaaay off. [edit] I probably should mention I ran the 225s on Revolutions, not stock wheels... MarkL |
Trekkor |
Dec 29 2006, 02:33 PM
QUOTE Anyone know how low profiles look on western rims? Yes, I do. KT Attached image(s) |
TROJANMAN |
Dec 29 2006, 02:38 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
i run 205/50's on stock 4 bolt fuchs
Hammy |
Dec 29 2006, 03:32 PM
PORobinSCHE |
Dec 29 2006, 05:03 PM
Member Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 |
Never seen lo pros on Westerns....but lo sidewalls can cause high revs on the freeways, throw off the speedo, lower top speed and higher oil temps....BUT, they look good, give you better out of the hole performance (trailer trash re-gearing) and better grip.....choose yer poison. i have 205/60-15 on my 71. i think these are Western's or Gurney wheels. RJJ (IMG:style_emoticons/default/driving.gif) Attached image(s) |
Lo-Fi Version | Time is now: 14th May 2024 - 03:27 PM |
