How do I remove this piece?, big piece behind the seats |
Cevan |
Dec 28 2006, 09:23 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
How do I remove the big interior piece behind the seats? I have the seats and armrest removed. I removed the screws on the bottom of this piece but I'm not sure how to unfasten it from the firewall. Thanks.
ejm |
Dec 28 2006, 09:25 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Pull it away at the bottom and then slide it downwards
markb |
Dec 28 2006, 09:27 PM
That's called the backpad. There are 4 screws at the bottom. Remove them, pull the bottom forward, and slide it down. There are clips that hold the top of it in place. Don't pull it from the top or you'll pull the clips loose. The wiring for the light run behind it, so when you go to reinstall, make sure to route the wires back up.
Damn, Ed beat me to it. (IMG:style_emoticons/default/biggrin.gif) |
MrKona |
Dec 28 2006, 09:30 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
This might go without saying, but don't forget to remove the engine lid knob as well. It just unscrews.
markb |
Dec 28 2006, 09:31 PM
Good catch! I forgot that. (IMG:style_emoticons/default/sad.gif)
McMark |
Dec 28 2006, 10:19 PM
Watch the interior light wires. (IMG:style_emoticons/default/wink.gif)
boxstr |
Dec 28 2006, 11:11 PM
The engine lid knob must be removed but you must also remove the finish piece that also screws on. There are two screws that secure the cover over the park brake pivot and cables, remove it, makes life easier.
CCLINBACKPADDEDROOM |
Cevan |
Dec 29 2006, 07:16 AM
Thanks!! I got the engine lift knob.
Joe Bob |
Dec 29 2006, 08:31 AM
Disconnect the fuse and/or the battery...that interior light wire can ground out and spark....
Lo-Fi Version | Time is now: 12th May 2024 - 04:41 PM |
