Cevan
Dec 28 2006, 09:23 PM
How do I remove the big interior piece behind the seats? I have the seats and armrest removed. I removed the screws on the bottom of this piece but I'm not sure how to unfasten it from the firewall. Thanks.
ejm
Dec 28 2006, 09:25 PM
Pull it away at the bottom and then slide it downwards
markb
Dec 28 2006, 09:27 PM
That's called the backpad. There are 4 screws at the bottom. Remove them, pull the bottom forward, and slide it down. There are clips that hold the top of it in place. Don't pull it from the top or you'll pull the clips loose. The wiring for the light run behind it, so when you go to reinstall, make sure to route the wires back up.
Damn, Ed beat me to it.
MrKona
Dec 28 2006, 09:30 PM
This might go without saying, but don't forget to remove the engine lid knob as well. It just unscrews.
markb
Dec 28 2006, 09:31 PM
Good catch! I forgot that.
McMark
Dec 28 2006, 10:19 PM
Watch the interior light wires.
boxstr
Dec 28 2006, 11:11 PM
The engine lid knob must be removed but you must also remove the finish piece that also screws on. There are two screws that secure the cover over the park brake pivot and cables, remove it, makes life easier.
CCLINBACKPADDEDROOM
Cevan
Dec 29 2006, 07:16 AM
Thanks!! I got the engine lift knob.
Joe Bob
Dec 29 2006, 08:31 AM
Disconnect the fuse and/or the battery...that interior light wire can ground out and spark....
