engine rubber seal, where can I get one |
bernbomb914 |
Nov 17 2003, 09:37 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I need a new rubber seal for the engine compartment to go on the tin. PP does not have one and has no suggestions.
Bernie |
Qarl |
Nov 17 2003, 09:39 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Are you talking about the seals on all four sides of the engine bay that seal up against the engine tin?
Seek out jbfrenz on e-bay. He has sets of all 4 for about $100. |
bernbomb914 |
Nov 17 2003, 09:43 PM
yes those are the ones. doing a new 2.0 L motor and I need all the seals
Bernie |
Qarl |
Nov 17 2003, 09:46 PM
nyum96 |
Nov 17 2003, 09:48 PM
Member Group: Members Posts: 75 Joined: 27-September 03 From: Roswell, GA Member No.: 1,200 |
www.pap-auto.com
Left and right are 7.68 each. The rear is 28.02. The rubber is just like the original. http://www.pap-parts.com/store/prodinfo.as...item=2&mitem=21 http://www.pap-parts.com/store/prodinfo.as...item=3&mitem=21 Barry |
RustyWa |
Nov 17 2003, 09:54 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
Alright...those prices are to good to be true! How is the quality? They are not that foam crap are they?
(IMG:style_emoticons/default/idea.gif) Hmmm...Might have to update my Xmas list! |
Nov 17 2003, 09:58 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(RustyWa @ Nov 17 2003, 07:54 PM) Alright...those prices are to good to be true! How is the quality? They are not that foam crap are they? (IMG:style_emoticons/default/idea.gif) Hmmm...Might have to update my Xmas list! yepp, if that is the real deal, i'll be ordering a set too. soooo, who's first? we need a guinea-pig, aehm, volunteer, i mean ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
bernbomb914 |
Nov 17 2003, 10:22 PM
I orderded the left and rear seal they do not have right side?
I bought two left sides Bernie |
nyum96 |
Nov 17 2003, 10:25 PM
They are real. I was happy to see that the one I ordered (left side) was real rubber and still had the power on it. for 7.68, why not? Y'all have instired me to order the rest. I'll let y'all know. For $50 you can have the whole set!
Barry |
Nov 17 2003, 10:26 PM
QUOTE(bernbomb914 @ Nov 17 2003, 08:22 PM) I orderded the left and rear seal they do not have right side? I bought two left sides let us know how it worked out. the original ones come pre-bent, sooo, you can't really exchange them. well, you might when they're new and not hard and brittel. anywho, post pics ... (IMG:style_emoticons/default/wavey.gif) Andy |
nyum96 |
Nov 17 2003, 10:32 PM
WHen you say pre-bent, do you mean this... The picture sucks but you can see the idea. It has a hard rubber for the channel and bends around to clip on the tin at the bottom. I'm going to inquire tomorrow about the right. The company split into 2 seperate areas, used and new parts. I'm sure they have the right. The left will not work as the right since there is an angle that joins the left and right to the front tin seal. I would call them tomorrow and get the right. Anywhich way, $7.68, spare!
(IMG:http://www.digitalpose.com/mbr/1/30973/p/581271_5094614152331647548_vl.jpg) (IMG:http://www.digitalpose.com/mbr/1/30973/p/581273_4508185975743630139_v.jpg) BB |
Nov 17 2003, 10:37 PM
QUOTE(nyum96 @ Nov 17 2003, 08:32 PM) WHen you say pre-bent, do you mean this... nope, the factory ones are bent to fit the shape of the sheetmetal. see green lines in attached pic ... the original ones are too hard to bend to fit the other side, so you usually can't exchange them. Andy Attached image(s) |
nyum96 |
Nov 17 2003, 10:40 PM
Then no, its a solid piece with no bends..
BB |
bernbomb914 |
Nov 17 2003, 10:42 PM
if i cant use it im only out $8.00 and I can use it next time
Bernie |
RustyWa |
Nov 18 2003, 12:02 AM
That end view photo, showing the section that slides into the channel, looks a little different than what I remember what my existing ones looked like....BUT...... it looks close enough and the price is right.
Lo-Fi Version | Time is now: 8th May 2024 - 10:13 PM |
