| quadracerx |
Jan 3 2007, 07:43 PM
Member ![]() ![]() Group: Members Posts: 428 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Hi guys...
Where is the best place to purchase some new replacement "Hell Hole/Battery Area Replacement metal"? I also need to know if anyone has a simple way to open the trunk, I have the keys for the doors and they are stiff but work. The same key does nothing to the trunk. Before I take a slide hammer to the lock...is there a better way? OR is there someone who has a complete lock set? Thanks... Steve PS Maybe I should have put this in the Classifieds? Sorry |
| jr91472 |
Jan 3 2007, 08:10 PM
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
| McMark |
Jan 3 2007, 08:12 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Hell hole metal is usually just hand formed from flat sheet metal. Those pieces from donor cars are usually just as bad.
Don't slide hammer the lock. You will do SO MUCH MORE DAMAGE. You'll need lots of socket extensions, but you can get a 10 mm socket in from the engine bay and unscrew the two bolts that hold the trunk latch in place. |
| t collins |
Jan 3 2007, 08:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
| Rusty |
Jan 3 2007, 09:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,991 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States
Check to make sure that you're not using the Valet key on the trunk lock... because it won't work.
| ClayPerrine |
Jan 3 2007, 09:51 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
| Rusty |
Jan 3 2007, 09:53 PM
| markb |
Jan 3 2007, 09:59 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
| Rusty |
Jan 3 2007, 10:01 PM
Short people are sneaky...
| ws91420 |
Jan 3 2007, 10:02 PM
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
| ClayPerrine |
Jan 3 2007, 10:05 PM
I just drove the car to the locksmith, and gave them a brand new key and had them cut it from the lock, and not an old key. They also cut a plain metal key on one side only. The reason for this was to provide a "template" key for any future keys we have cut. That one sided key will never wear, because it can't be used in the car, but it has the correct pattern for the locks. I would suggest getting one cut like that yourself. And yes, I got your mail. |
| 914rrr |
Jan 3 2007, 10:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,997 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
Does the new engine shelf / hell hole metal piece extend all the way to the firewall, or is fabrication still needed?
I'm getting ready to replace an engine shelf that was butchered due to dealer AC installation. |
| quadracerx |
Jan 3 2007, 10:18 PM
Thanks you guys....that Restoration Design place is awsome....it has everything I need...
As for the lock issue on the trunk....if I have a super long extension...if I can get in from the engine bay ill try... But are you saying that if a locksmith will do a house call he could get it unlocked and make a key? I will do that as a last resort... Thanks... Steve |
| 914rrr |
Jan 3 2007, 10:23 PM
Thanks you guys....that Restoration Design place is awsome....it has everything I need... As for the lock issue on the trunk....if I have a super long extension...if I can get in from the engine bay ill try... But are you saying that if a locksmith will do a house call he could get it unlocked and make a key? I will do that as a last resort... Thanks... Steve Several years ago I called AAA to unlock my teener at a convention center parking lot. The old guy they sent out actually hand filed a key to fit the lock on the spot! Not sure if anybody still does house calls like that. |
| Chris Pincetich |
Jan 4 2007, 12:39 AM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Restoration design was great to work with. I wasn't sure how bad my rust was, and it is usually worse than you can see at first, so I ordered several pieces. When I didn't need to use them all, I was able to return them minus a small re-stock fee. (IMG:style_emoticons/default/beerchug.gif)
| mrhurtalot |
Jan 4 2007, 04:22 AM
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
How many 914 owners actually have all the locks matching.... much less a valet key? me! (IMG:style_emoticons/default/boldblue.gif) but my pasenger side lock is borked! any way. find a friend with a pick set. or a set of auto jigglers more likely |
Lo-Fi Version | Time is now: 7th December 2025 - 07:18 PM |
