need the lower outer firewall, Anyone got any suggestions as to where I can get one? |
IanStott |
Jan 7 2007, 08:43 AM
Member Group: Members Posts: 226 Joined: 13-June 04 From: Moncton,New Brunswick,Canada Member No.: 2,199 |
I am rustoring my 74, the outer lowewr firewall is just too fwar gone to repair so I was looking to see if I could get one. Bill at Restoration design doesn't make them anymore. Even used in decent shape is very acceptable. Any help or suggestions much appreciated.
Ian Stott Moncton Canada |
Joe Owensby |
Jan 7 2007, 12:32 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Check with some of the other suppliers, Automobile Atlanta, etc. They used to carry these.
Also, how bad is yours? Mine was only rusted along the lower section (up about 1/2 inch) where the floor pan was welded in, and only on the outboard section. The center section of the car where the cable and shifter pass throughs are, was not rusted. I cut out about 1 inch of the lower section of this where the rust was, and then made a piece to weld it to fit the floorboard contours. I decided to do this after watching the on line video from Automobile Atlanta, showing the repairs (recommend you see this). They said to only cut out the minimum amount necessary. if I had it to do over, I would probably order a fabricated piece and just use the bottom 1" of it, but what I did was not really that much work, and should be just as strong. While I had the area opened up, I cleaned and POR15 coated all the inside areas so I won't have to worry about rusting from inside. This was pretty easy, as I completed the inner and outer firewalls first, and then welded in a floorpan. Good luck. Joe O. |
boxstr |
Jan 7 2007, 12:45 PM
I have one of these....firewall pics show the front and back. This is a new NOS never used Factory piece.
camp914@comcast.net for details CCL Attached image(s) |
stepuptotheMike |
Jan 7 2007, 12:55 PM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
Check with some of the other suppliers, Automobile Atlanta, etc. They used to carry these. Also, how bad is yours? Mine was only rusted along the lower section (up about 1/2 inch) where the floor pan was welded in, and only on the outboard section. The center section of the car where the cable and shifter pass throughs are, was not rusted. I cut out about 1 inch of the lower section of this where the rust was, and then made a piece to weld it to fit the floorboard contours. I decided to do this after watching the on line video from Automobile Atlanta, showing the repairs (recommend you see this). They said to only cut out the minimum amount necessary. if I had it to do over, I would probably order a fabricated piece and just use the bottom 1" of it, but what I did was not really that much work, and should be just as strong. While I had the area opened up, I cleaned and POR15 coated all the inside areas so I won't have to worry about rusting from inside. This was pretty easy, as I completed the inner and outer firewalls first, and then welded in a floorpan. Good luck. Joe O. Joe, do you happen to have a link to that video? Thanks, Mike |
IanStott |
Jan 7 2007, 08:11 PM
I have one of these....firewall pics show the front and back. This is a new NOS never used Factory piece. camp914@comcast.net for details CCL Those pieces in my car are ok, it is the lower part of the firewall that is a big rusted mess. Thanks for replying though. Ian Stott |
tracks914 |
Jan 7 2007, 08:21 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Mike:
I just replaced my lower 2"x 12" on each side but the middle was good. It's not a big deal and probably easier than you think. If the section around your cable tubes is OK then its easily done. If you have to replace all around your tubes its a PITA. |
IanStott |
Jan 7 2007, 08:29 PM
Mike: I just replaced my lower 2"x 12" on each side but the middle was good. It's not a big deal and probably easier than you think. If the section around your cable tubes is OK then its easily done. If you have to replace all around your tubes its a PITA. I am going to look at this area again with my body man, sounds like you are very familiar with what I am up against. If the part is available would you recommend getting it? Ian Stott |
tracks914 |
Jan 7 2007, 08:32 PM
Take some pictures of it and email them to me. Of all the rust on my car, and there was a lot, this area was in relatively good shape.
IanStott |
Jan 7 2007, 08:41 PM
Take some pictures of it and email them to me. Of all the rust on my car, and there was a lot, this area was in relatively good shape. I'll do that but I don't seem to be able to post pics, I have tried unsuccessfully in the past and gave up in frustration, I am not very computer savvy plus I am on very slow dial up. I do have a digital camera which takes nice pictures, could I e-mail them to you directly, I have been successful at doing that to relatives. Ian Stott Moncton |
ws91420 |
Jan 7 2007, 08:45 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Try Resteration Design they list a lower left and right firewall.
IanStott |
Jan 7 2007, 09:22 PM
I have purchased all I good from Restoration Design, great quality parts, Bill at RD was great to deal with as well, he told me at that time he wasn't making that lower outer firewall piece anymore. I will check with him to see if things have changed. Ian Stott |
ws91420 |
Jan 7 2007, 09:23 PM
He has pics posted on the web site did'nt try to see if it could be ordered though.
Mid_Engine_914 |
Jan 7 2007, 09:32 PM
Member Group: Members Posts: 195 Joined: 22-September 06 From: Left Coast Member No.: 6,888 |
As far as I know that lower firewall section hasn't been available from Restoration Design for a long time now. I brought my car in to a local shop back in November to have the firewall and hell-hole rust repaired and he fabbed up his own metal patch panels for the firewall area. Here are some before and after pics (click on pics to enlarge).
(IMG:http://img489.imageshack.us/img489/8601/firewallrust1mr2.th.jpg) (IMG:http://img489.imageshack.us/img489/7641/firewallrust2dk1.th.jpg) (IMG:http://img489.imageshack.us/img489/8430/firewallrust3kh2.th.jpg) (IMG:http://img489.imageshack.us/img489/5651/firewallrust4wi5.th.jpg) |
dr914@autoatlanta.com |
Jan 8 2007, 10:56 AM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I am rustoring my 74, the outer lowewr firewall is just too fwar gone to repair so I was looking to see if I could get one. Bill at Restoration design doesn't make them anymore. Even used in decent shape is very acceptable. Any help or suggestions much appreciated. Ian Stott Moncton Canada Hi Ian. Yes we do make the part but am sure that Bill makes it two and if you are happy dealing with him then I would recommend that you continue. We NEVER would want to take business away from any 914 manufacturer as we really appreciate anyone who makes 914 parts these days! Of course there is another story about 914 sheet metal suppliers! |
Instru-Mental |
Newbie Group: Members Posts: 14 Joined: 26-December 06 From: Canada Member No.: 7,386 |
Hi Ian,
Is that the black chassis that you bought from freezing14? If so, my dad hauled it down to Moncton for you. I have a stash of NOS and repro parts that I've been accumulating and think I have the part you are looking for. I'll double check and get back to you. If you don't need it ASAP I might be able to arrange cheap safe passage for it to Moncton. Cheers Todd |
IanStott |
Jan 8 2007, 06:22 PM
[quote name='Instru-Mental' date='Jan 8 2007, 08:56 AM' post='844840']
Hi Ian, Is that the black chassis that you bought from freezing14? If so, my dad hauled it down to Moncton for you. I have a stash of NOS and repro parts that I've been accumulating and think I have the part you are looking for. I'll double check and get back to you. If you don't need it ASAP I might be able to arrange cheap safe passage for it to Moncton. Cheers Todd Thanks Todd, I would appreciate that, and you are correct I don't need it yesterday. I wasn't home when your Dad dropped off the black body, I was in New Jersey so I didn't get to meet him. I am willing to pay you for the part, did you want me to call you to arrange payment and other details? I would be interested in some other items, we could talk about that. I got the impression from the Auto Atlanta guy I couldn't buy from him as I had bought some parts from Restoration Design and there is some kind of bad blood between them so he is not interested in selling me anything. I really didn't know how to respond to that. Ian Stott |
Bartlett 914 |
Jan 8 2007, 08:58 PM
[quote name='IanStott' date='Jan 8 2007, 04:22 PM' post='845050']
[quote name='Instru-Mental' date='Jan 8 2007, 08:56 AM' post='844840'] Hi Ian, Is that the black chassis that you bought from freezing14? If so, my dad hauled it down to Moncton for you. I have a stash of NOS and repro parts that I've been accumulating and think I have the part you are looking for. I'll double check and get back to you. If you don't need it ASAP I might be able to arrange cheap safe passage for it to Moncton. Cheers Todd Thanks Todd, I would appreciate that, and you are correct I don't need it yesterday. I wasn't home when your Dad dropped off the black body, I was in New Jersey so I didn't get to meet him. I am willing to pay you for the part, did you want me to call you to arrange payment and other details? I would be interested in some other items, we could talk about that. I got the impression from the Auto Atlanta guy I couldn't buy from him as I had bought some parts from Restoration Design and there is some kind of bad blood between them so he is not interested in selling me anything. I really didn't know how to respond to that. Ian Stott [/quote] I have been following your thread because I am about to do the same repair. I think you read George wrong unless there was something else said between you two. I think he was only saying he wasn't trying to take business from resto. I am sure he will sell to you. I am not sure exactly when I can post pictures of my progress but I will as soon as I have some (progress that is). |
jd74914 |
Jan 8 2007, 09:15 PM
AutoAtlanta makes it . . . he just said that if resto design does too and you like them buy it there because he doesn't want to take away their business.
nomore9one4 |
Jan 8 2007, 09:17 PM
Member of the Eastcoast Thread Killers Club Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None |
Todd I got the impression from the Auto Atlanta guy I couldn't buy from him as I had bought some parts from Restoration Design and there is some kind of bad blood between them so he is not interested in selling me anything. I really didn't know how to respond to that. Ian Stott (IMG:style_emoticons/default/WTF.gif) and you read that were? (IMG:style_emoticons/default/wacko.gif) |
Instru-Mental |
Jan 9 2007, 07:58 AM
Thanks Todd, I would appreciate that, and you are correct I don't need it yesterday. I wasn't home when your Dad dropped off the black body, I was in New Jersey so I didn't get to meet him. I am willing to pay you for the part, did you want me to call you to arrange payment and other details? I would be interested in some other items, we could talk about that. I got the impression from the Auto Atlanta guy I couldn't buy from him as I had bought some parts from Restoration Design and there is some kind of bad blood between them so he is not interested in selling me anything. I really didn't know how to respond to that. Ian Stott [/quote] Ian, PM your phone number and I'll give you a shout. My father will be travelling down this way in the near future (and heading back to Moncton). I have a number of duplicate parts. I can probably send a pic on Saturday (too busy through the week). Cheers Todd |
Lo-Fi Version | Time is now: 14th May 2024 - 06:06 PM |
