Its the final countdown, progress thread |
type11969 |
Jan 8 2007, 09:29 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I've had this 71 for 3 years now and I've only driven it for 10 minutes before I bought it. I figure if I haven't made serious progress by the spring, she is getting stripped and scrapped. You'll see why. Its probably only a parts car, but I want to learn how to weld, and if I can get this thing back on the road, I think I will be well on my way. I'll start from the beginning:
The exterior, looks harmless enough: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/914.jpg) The interior, looks pretty good (wait, what was that saying about wrapping a piece of poo in a pretty package): (IMG:http://i19.photobucket.com/albums/b188/type11969/914/914012.jpg) Long looks okay at first glance: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/914009.jpg) Wait, umm, is this factory installed golf ball sized hunks of epoxy and bondo: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404015.jpg) Yum: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404010.jpg) Delicious: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404012.jpg) Craptacular: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/914-2018.jpg) Brace yourself (also have another brace running to the drivers side door jamb, couldn't find that pic): (IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404001.jpg) Couldn't find any pics of the lovely riveting and brazing job a PO did with re-attaching the portion of the fender below the sail, but I hacked that focker off: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/121304002.jpg) Mmm, clean: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/121304013.jpg) Also found after removing the interior that the passenger side was once used as a pool, the entire lower inner corner of the long and bulkhead was gone. PO crappily arc welded a new floorpan in, but didn't fix any of the other damage: (IMG:http://i19.photobucket.com/albums/b188/type11969/914/Picture069.jpg) (IMG:http://i19.photobucket.com/albums/b188/type11969/914/Picture070.jpg) (IMG:http://i19.photobucket.com/albums/b188/type11969/914/Picture071.jpg) (IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404002.jpg) Quick break, then pics of the repairs so far . . . |
type11969 |
Jan 18 2007, 07:11 AM
Thanks for the kudos, hopefully it is as strong as it looks. Only did some grinding just to make sure the crappy looking welds were strong. Now I have to make another internal doubler under what will be the cutout for the heater tube and an external piece to complete the shell and this inner long will be done!
With the replacement metal sold online I've noticed that it is only one layer thick . . . do any of you know if that one layer is as thick as the double or triple layers Porsche used from the factory? Seems like if it isn't you could end up with a pretty flexible car if you use them. -Chris |
dkos |
Jan 27 2007, 11:30 AM
say, "RUST"! Group: Members Posts: 295 Joined: 1-December 04 From: Philadelphia, PA Member No.: 3,204 Region Association: None |
Thanks for the kudos, hopefully it is as strong as it looks. Only did some grinding just to make sure the crappy looking welds were strong. Now I have to make another internal doubler under what will be the cutout for the heater tube and an external piece to complete the shell and this inner long will be done! With the replacement metal sold online I've noticed that it is only one layer thick . . . do any of you know if that one layer is as thick as the double or triple layers Porsche used from the factory? Seems like if it isn't you could end up with a pretty flexible car if you use them. -Chris Hi Chirs, We've been talking about two parts cars I found in the Philly area. I just found your resto thread. My story is similar to yours. Bought a car that looked ok. Started digging and found a big mess hidden under bondo, fiberglass and riveted in scrap metal (I think one piece was an old license plate!). My car's probably not worth repairing, but I'm learning a lot and having fun. I've been rebuilding my longs in a similar way and was concerned about rigidity too. I bought an aftermarket reinforcement piece made by Brad Mayuers (sp?). It's heavy (at least 1/8" thick), but it's stiff. |
dkos |
Jan 27 2007, 11:33 AM
Here are some pics of the Brad Mayuers piece. Top pic shows reinforcement piece on the ground and bottom shows it installed:
Attached image(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:41 PM |
