nocones |
Sportscar lunatic ![]() ![]() Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 ![]() |
So I'm getting ready to reinstall my 915 in the 914/8 and am not sure how much swepco it will take.
I ordered 1 gallon, will that be enough? Also, I needed a new seal for the shift -shaft as the old one was leaking a little. Does this seal install externally? Or do I need to pull the rear cover to install? Thanks! |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,107 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
It takes 3 liters, 1 gallon should fill it with some to spare.
Sorry no help on the seal. So I'm getting ready to reinstall my 915 in the 914/8 and am not sure how much swepco it will take. I ordered 1 gallon, will that be enough? Also, I needed a new seal for the shift -shaft as the old one was leaking a little. Does this seal install externally? Or do I need to pull the rear cover to install? Thanks! |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
I like cheap Valvoline transmission fluid, it works good! Where is redbeard when we need him? He used to hate $wepco. I think it works fine, just too $$$ for me, especially when it will all leak out eventually. (IMG:style_emoticons/default/dry.gif)
nocones |
I like cheap Valvoline transmission fluid, it works good! Where is redbeard when we need him? He used to hate $wepco. I think it works fine, just too $$$ for me, especially when it will all leak out eventually. (IMG:style_emoticons/default/dry.gif) Thanks, I already have the jug-o' swepco, so that is what I'll use. |
mightyohm |
At least you will be able to tell which fluid is leaking by the color. (IMG:style_emoticons/default/smile.gif)
(I am still in search of the elusive non-leaking Porsche.) |
914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None ![]() |
915s love SWEPCO!
Definately use it. 1 gal is a little more than enough. |
Lo-Fi Version | Time is now: 9th July 2025 - 08:31 AM |
