| Hammy |
Jan 13 2007, 02:46 AM
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California |
So I received my Dakota Digital CHT gauge today (IMG:style_emoticons/default/mueba.gif) Looks great
Anyways, I have some questions and I want some answers (IMG:style_emoticons/default/cool_shades.gif) 1 - The gauge sender washer/loop/ring end is just a hair too small to slide/thread onto the spark plug. I did order the correct size, 14mm, but it seems still just a tad too small. Is it ok to open the hole up just a little tiny bit more? It seems highly doubtful it'd be a problem, but just checking. 2 - Does the sender ring replace the spark plug washer? If not, does it go in front of the washer, or in between the washer and plug? 3 - The gauge has a night dimming feature so that when the headlights are turned on, it dims the output of the gauge (it's a digital display). I notice there are some unhooked male spade connectors in the center tunnel wiring harness, behind the shifter. They have a plastic protector box around them. What are they for? I think I've read that they're for center console gauge lights, correct? Thanks for any help |
| Dave_Darling |
Jan 13 2007, 12:24 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
#3 -- The wires are for all of the center console stuff. Look for a grey wire or a black wire with a blue stripe--those are the instrument light circuit.
--DD |
| Aaron Cox |
Jan 16 2007, 01:24 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
bump for hammy to get some answers on CHT
| McMark |
Jan 16 2007, 01:27 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
1- Yep, I've seen people grind them. I can't say for sure if it affects the readings, but I doubt it does.
2- I leave the crush washer on. 3- Those wires sound like the right ones. Use a voltmeter to check if they come on when you turn the headlights on. (IMG:style_emoticons/default/wink.gif) |
| Rand |
Jan 16 2007, 01:29 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
File the inside with a round file just enough so you can thread it on. When it gets past the threads there is a groove it will fit freely in. It won't hurt anything.
| SLITS |
Jan 16 2007, 01:55 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Just thread the ring on like you were screwing the sparkplug into it's hole. It'll work.
| Hammy |
Jan 16 2007, 05:02 PM
Thanks AA for the bump
I tried to thread it onto the plug like it was a washer but it wouldn't tighten down without bending and breaking the sender loop. I ended up opening the loop a tiny bit with with a fat drill bit and it slid on (IMG:style_emoticons/default/smile.gif) the wires in the center tunnel worked perfectly.... I've got switched 12v, ground and power from the lights for the dimming feature (IMG:style_emoticons/default/clap56.gif) Works great So far head temps only hit about 310 around town under heavy load. The real test comes when I hit the freeway and some hills... :gulp: Thanks all - Z. |
| spunone |
Jan 16 2007, 05:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Hammy which gauge did you buy and how long where the wires did you dash mount or in the center consule
| Hammy |
Jan 16 2007, 05:29 PM
Hammy which gauge did you buy and how long where the wires did you dash mount or in the center consule I got the black Odyssey Series II gauge, you can see it here. I mounted it in my center console. I can get pics if you want. it's pretty expensive compared to the VDO CHT gauges but this one is temperature compensated and spot on, really easy to read numbers too. The reaction time of it is really quick too... I feel it was well worth it. I had to order an 18 foot length wire (part # SEN-11-8) because that apparently was the only one with a 14mm sender thats needed for our plugs. You have to find that sender in their online catalog separately and add it to your cart separately because it's not listed on the drop down choices on the gauge pages... |
| spunone |
Jan 16 2007, 06:22 PM
Wonder if you can put on a switch and use another sender and do both sides ??
| Rand |
Jan 16 2007, 06:24 PM
| Hammy |
Jan 16 2007, 09:27 PM
Wonder if you can put on a switch and use another sender and do both sides ?? Absolutely. Just don't cut the sender wires (IMG:style_emoticons/default/smile.gif) |
| spunone |
Jan 30 2007, 02:40 PM
Talked to the fellas at Dakota Dig nope can't use a switch unless its a special type around 200.00 gulp I'll say thats special so no on the switch >I also told them they should make a shorter sending unit for the 14mm plug like say 10 foot since it would be cheaper with less wire and there are millons of guys with Short cars LOL
| Hammy |
Jan 30 2007, 04:31 PM
Talked to the fellas at Dakota Dig nope can't use a switch unless its a special type around 200.00 gulp I'll say thats special so no on the switch >I also told them they should make a shorter sending unit for the 14mm plug like say 10 foot since it would be cheaper with less wire and there are millons of guys with Short cars LOL Bummer. Yeah I couldn't figure out why the 14mm was only available in 18 feet. pretty long. all coiled up under my console. |
| spunone |
Jan 30 2007, 04:34 PM
They say you can cut it just can't add to it at least thats what they told me
| Rand |
Jan 30 2007, 05:05 PM
My info said not to cut it at all... Don't shorten it, just coil up the excess. Like Hammy, I also have an extra bundle of wire behind my center console. (IMG:style_emoticons/default/laugh.gif)
But then again, mine is an analog VDO. Perhaps this digital unit is different. (IMG:style_emoticons/default/confused24.gif) |
| Aaron Cox |
Jan 30 2007, 05:33 PM
resistance changes with wire length right? so if they are designed to be accurate with 18 feet of wire... you leave it at 18 (IMG:style_emoticons/default/smile.gif)
| spunone |
Jan 30 2007, 05:57 PM
Ok so why did 1 sales scum then a tech guy say you may cut the wire.This is Dakota dig that I spoke to????
| spunone |
Jan 30 2007, 05:58 PM
Oh yeah I think they made the sender for a vw bus
| eeyore |
Jan 30 2007, 06:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
If you get the 12mm sender, you get a choice between 10, 14, & 18, or something like that.
They tell to to NOT cut the wire, but the interesting thing is the sender is 2 pieces. A short (1 foot) lead on the sender ring itself, then the remain length of wire. All bolted together with itty-bitty bolts and nuts. The gauge has adjustments for sender temp ranges, but not sender wire lengths. |
Lo-Fi Version | Time is now: 16th April 2026 - 05:49 PM |
