My Weekend Project, Removing the Backpad |
jgara962 |
Jan 13 2007, 04:48 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
My weekend project is to remove the backpad and rubber pad behind it. So far so good - the two combined weight 26 lbs! I'm going to put down some Dynamat Extreme and then lay a Morph carpet kit over the top.
One question. Do I need to remove all of the glue that is stuck to the firewall from the original pad, or do you think I can just lay the Dynamat over it? What should I use? So far I've tried Goof Off and a razor blade scrapper, but that's going to take a while and I already have a buzz going (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 07:24 AM |
