? for Clay about the tie rod swap |
spare time toys |
Jan 14 2007, 04:53 PM
Could you use a tramel bar to transfer the original tie rod measurement to the new rod? That way you shouldnt need to do the alignment. Thats how we change rod ends at work and not have to do a rerig of the system it comes off of.
ClayPerrine |
Jan 14 2007, 05:02 PM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Could you use a tramel bar to transfer the original tie rod measurement to the new rod? That way you shouldnt need to do the alignment. Thats how we change rod ends at work and not have to do a rerig of the system it comes off of. Yes, You could use a trammel bar to set the adjustments. But I have the alignment gauges, and I don't have a trammel bar. You can also use a tape measure and a piece of chalk to set the toe, but its not as accurate as alignment gauges that can measure to +/- 10 minutes of toe. |
Lo-Fi Version | Time is now: 28th May 2024 - 09:05 PM |
