Rear hub mods?, Looking for suggestions |
MartyYeoman |
Jan 19 2007, 02:20 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
To all:
I'm currently in the process of renewing both rear axles replacing all CV joints, boots, and bearings. I'm at the point where I have the the hubs (four bolt) out and want to know what I can do to them to provide myself 5 bolt options in the future. Here are some of my thoughts: 1) Drill and tap five bolt pattern into hub flange. This seems weak to me. Not enough wheel bolt engagement on the five bolt pattern. 2) Drill five bolt pattern, spotface rear of hub and install threaded boss to add thread depth to match four bolt pattern. Probably press fit with keeper keys to prevent rotation. 3) Forget about options and reinstall existing hubs unchanged. Personally I like idea two the best. What do you think?? |
914nerd |
Jan 19 2007, 02:32 PM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
Look up Eric Shea in the member vendors section
He sells 5-lug converted hubs that look to be quite well done and he has a good reputation around here |
Mueller |
Jan 19 2007, 02:44 PM
Look up Eric Shea in the member vendors section He sells 5-lug converted hubs that look to be quite well done and he has a good reputation around here Marty is a professional designer/machinest, I know he is capable of doing the mods (IMG:style_emoticons/default/smile.gif) Marty, I'd opt for #2 or #3...the problem with #2 is whether or not you'll have enough room to access on the farside to install the studs when the assembly is complete. I think Andy mentioned he once installed studs into his hubs while they were on the trailing arms. Another problem with #2 is ensuring that you get the studs perfectly perp. with the hub to wheel mounting surface. I think I'll be able to drop off the CV's this sat. |
914nerd |
Jan 19 2007, 02:47 PM
Well, given that piece of information, #2 if you reallly want the 5-lug and #3 if you don't really want them
MartyYeoman |
Jan 19 2007, 02:53 PM
I just took a look at Eric's converted hub's. He has studs installed and I was thinking of only adding additional threaded holes to allow either four or five bolt wheels to bolt up. Are lug bolts an issue with five bolt wheels? Is there a reason to only use studs?
Mueller |
Jan 19 2007, 03:03 PM
I just took a look at Eric's converted hub's. He has studs installed and I was thinking of only adding additional threaded holes to allow either four or five bolt wheels to bolt up. Are lug bolts an issue with five bolt wheels? Is there a reason to only use studs? new Porsches use bolts, my 3300 pound Volvo uses bolts....one threaded hole will remain common between the 4 lug and 5 lug, but there will be one that is pretty close (do a layout with your CAD system using 14mm holes and you'll see how close) |
Aaron Cox |
Jan 19 2007, 03:59 PM
eric spot faces and uses 7mm bosses... tacked onto the hub.
press the stud into the boss and blammo... same engagement depth as 911 hubs and 914/6 and early 914 hubs.... AA |
John |
Jan 19 2007, 04:32 PM
I like the studded hubs.
A. they hold the wheel up while you start the firs lug nut B. they allow you to visually know how many threads are engaged with the nut (if using the steel nuts) C. they can be replaced if one gets boogered (threaded holes are harder to replace) D. it's just the right thing to do. I like eric's hubs. I just prefer 911 hubs. (I still never recieved those, damn Post Office) |
plas76targa |
Jan 19 2007, 04:54 PM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
Hi Marty! (IMG:style_emoticons/default/hijacked.gif)
ditto what Aaron said. he put it better words than I could. Eric had a nice post on the drilling the hubs and the welded additions. Forgive for not looking it up to add here. All's fair on the east coast. Matt |
McMark |
Jan 19 2007, 05:07 PM
Huh.... Universal hubs would be interesting. Unbolt the four lug, bolt up a five lug. (IMG:style_emoticons/default/idea.gif)
I have some boxster five lug wheels you can borrow indefinitely. You'll need to find spacers to run them, but they'll fit stock fenders. |
914werke |
Jan 19 2007, 07:30 PM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/confused24.gif) waste of time .
Ill sell you a set that are already drilled and include the alloy bolts (IMG:style_emoticons/default/smile.gif) |
Aaron Cox |
Jan 19 2007, 07:31 PM
they cant be universal...
youhave to press a stud thru one of the originalholes.... that means you have to ream out those threads..... |
Eric_Shea |
Jan 19 2007, 07:37 PM
Mike I've sent a couple e-mails. Are you available? I don't have my database with your phone number. Can you let me know CV status?
Aa, I think they're talking about 4-5 "threaded" hubs... cool idea. Rotor would have to be drilled to match. |
Aaron Cox |
Jan 19 2007, 07:43 PM
Mike I've sent a couple e-mails. Are you available? I don't have my database with your phone number. Can you let me know CV status? Aa, I think they're talking about 4-5 "threaded" hubs... cool idea. Rotor would have to be drilled to match. OHHHH!!! why? LOL btw... why not use /6 rotors? |
Eric_Shea |
Jan 19 2007, 07:44 PM
well... in that example you wouldn't be able to go back to 4-lug. (IMG:style_emoticons/default/wink.gif)
(switch back and forth) |
Aaron Cox |
Jan 19 2007, 08:09 PM
well... in that example you wouldn't be able to go back to 4-lug. (IMG:style_emoticons/default/wink.gif) (switch back and forth) you are a closet transvestite arent you.... (switch back and forth) |
MartyYeoman |
Jan 19 2007, 09:11 PM
I have some boxster five lug wheels you can borrow indefinitely. You'll need to find spacers to run them, but they'll fit stock fenders. Thanks for the offer Mark. I will definitely keep it in mind. (IMG:style_emoticons/default/clap56.gif) |
MartyYeoman |
Feb 10 2007, 08:36 PM
Just finished these. Now I can go either way. (Four or Five lug that is.)
John |
Feb 10 2007, 09:42 PM
Well for that to work out for you, you will still need to custom drill every rear rotor that you buy for the car. With a shared hole, you could have used a standard 914-6 or 911 vented rear brake rotor (the screw holes would line up).
It would still be cool to be able to use 4-lug OR 5-lug wheels without changing setups. It could mess with some heads until they see your secret. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 AM |
