Tire compounds to use for AX on loose asphalt and cold concrete?, what do you guys recommend? |
nine14cats |
Jan 24 2007, 01:27 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Since we lost Alameda Naval Station and its wonderfully grippy concrete as an AX venue, it appears the majority of our AX's will be at Candlestick's loose asphalt and beer bottle surface and at Marina's cold concrete. Which AX tires would work at these venues?
I have a set of Kumho V710's for AX that should work at Marina's concrete. Last year when Randal and I ran the 911 there even with 2 drivers we couldn't get any heat in the Goodyear slicks with R250 compounds. Andrew Blyholder had the same problem. I felt the tires on someone that was running the V710's and they were much hotter and stickier. For Candlestick, there is alot of loose debris and it's asphalt. The surface is generally cool there as well. Will the V710's work there or is it a waste and do I just run my heatcycled Victoracers from the track there? Or do Hoosiers work better on asphalt and beer bottles? What's the stickiest tire for the given conditions: 1. Cold ambient temp, loose asphalt 2. Cold ambient temp, concrete with gravel in the paddock area. Thanks, Bill P. |
Jan 26 2007, 12:43 AM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have a set of Kumho V710's for AX that should work at Marina's concrete. Last year when Randal and I ran the 911 there even with 2 drivers we couldn't get any heat in the Goodyear slicks with R250 compounds. Andrew Blyholder had the same problem. I felt the tires on someone that was running the V710's and they were much hotter and stickier. interesting ... (IMG:style_emoticons/default/idea.gif) the R250 i got from you usually warm up after the first run and stick like glue by the 3rd time around. even on the colder days. (which is used losely here, after all, we're in CA) ... maybe suspension setup is a factor here too. and driving style. ??? (IMG:style_emoticons/default/confused24.gif) but then again, the R250 is all i ever used, so i can't compare to other brands. i'm stubborn, i tend to stick (pun intended) with what i know and like ... (IMG:style_emoticons/default/driving.gif) Andy |
Chris Pincetich |
Jan 26 2007, 11:20 AM
The 2007 PCA GGR calander is chock full of Alameda events. Are you sure that we can't run at Alameda? (IMG:style_emoticons/default/dry.gif)
nine14cats |
Jan 26 2007, 12:01 PM
The 2007 PCA GGR calander is chock full of Alameda events. Are you sure that we can't run at Alameda? (IMG:style_emoticons/default/dry.gif) Hi Chris, Are you sure you weren't looking at 2006? When I call up the 2007 calendar for AX and also the general GGR calendar, it says Candlestick and Marina, but makes no mention of Alameda. Here's what I was looking at: PCA GGR AX calendar Thanks, Bill P. |
Chris Pincetich |
Jan 26 2007, 12:39 PM
(IMG:style_emoticons/default/chair.gif)
OK, I've finished my morning coffee. That must have been 2006 I saw.. Alameda was only 15 minutes from my house! I'm bummed. |
Randal |
Jan 26 2007, 01:31 PM
(IMG:style_emoticons/default/chair.gif) OK, I've finished my morning coffee. That must have been 2006 I saw.. Alameda was only 15 minutes from my house! I'm bummed. Yes, a very sad day, but they are working to get it back. |
jhadler |
Jan 26 2007, 02:54 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Be thankfull that you have Candlestick! There are meny regions around the country that considera site like Candlestick to be Nirvana. I do know how you feel though. We jsutrecently lost DIA as a site (acres of fresh concrete), and previous sites are no longer available.
I used to run at Candlestick a number of years ago (PCA and SCCA), and I think it's a pretty darn good site. Yes, the pavement can be a little loose, but it's not -bad- by any stretch. If you're looking for last available tenth, the new Hoosiers are still considered the faster tire. Neither the Hoosier or 710 are ideal for that surface, but then, nothing really is. On -really- loose asphalt I've seen street shod cars fare better than those that had race tires. -Josh2 |
Trekkor |
Jan 27 2007, 12:58 AM
Street sweeper...
grantsfo |
Jan 27 2007, 07:37 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Anyone else see Altamont as a venue for GGR. That has potential.
Randal |
Jan 27 2007, 12:05 PM
Anyone else see Altamont as a venue for GGR. That has potential. It will depend upon how much space is available AWAY from those walls. I've never forget when we used to run Dublin, i.e., the police site for high speed training. On one side there was this big concrete wall and one day a turbo lost it, skidded across a whole bunch of asphalt and just about kissed the wall. Scary. |
Jan 27 2007, 03:17 PM
Street sweeper... (IMG:style_emoticons/default/agree.gif) that shouldn't cost to much to rent and would take care of most of the lose debris ... (IMG:style_emoticons/default/smile.gif) Andy |
Trekkor |
Jan 27 2007, 03:33 PM
I think they can be hired for $100. They can make three or four passes of the course during the drivers meeting.
This would allow drivers to run anywhere on the course they want to. Not just where the marbles aren't. (IMG:style_emoticons/default/wink.gif) KT |
nebreitling |
Jan 27 2007, 08:11 PM
there are ways to set-up altamont as an AX that would keep people pretty far from the wall. while i'd love to run altamont as a road-course at an AX, i can understand that those in a a new 997 might not want to put their cars at risk.
Lo-Fi Version | Time is now: 1st May 2024 - 08:21 PM |
