Fuel Lines Buddy Sale, Through St. Valentine's Day '07 |
ChrisFoley |
Jan 30 2007, 09:26 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Now through valentines day:
Purchase any two sets of fuel lines, for you and a buddy, and take $25 off the order. A "set" includes a single supply line for carbs. The entire order must be made with a single payment and shipped to a single address. Regular prices, including delivery: Single line - $50 Pair (specify early or late fuel pump location) - $79 4pcs (includes 2pc engine comp lines) - $115 Anyone who desires -6AN fittings on the ends - add $20 each fitting. Paypal to sales@tangerineracing.com |
orange914 |
Feb 16 2007, 02:48 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
1 do you have a line set to convert a 73 to front pump?
2 what pieces are included? 3 do you make a fuel rail with provisions for a pressure gauge? 4 how much w/ s/h? (IMG:style_emoticons/default/beerchug.gif) |
ChrisFoley |
Feb 16 2007, 03:57 PM
1 do you have a line set to convert a 73 to front pump? 2 what pieces are included? 3 do you make a fuel rail with provisions for a pressure gauge? 4 how much w/ s/h? (IMG:style_emoticons/default/beerchug.gif) My late style set is perfect for conversion to front pump. You have a choice of going with just the tunnel lines (both 5/16") or the 4 pc set that includes two 5/16" engine comp. lines. Prices including shipping are $79 (2pc) or $115 (4 pc). I don't make fuel rails. IIRC many stock rails have provisions for a pressure gauge with a tee between the injector take-offs facing up and out. |
orange914 |
Feb 16 2007, 04:21 PM
1 do you have a line set to convert a 73 to front pump? 2 what pieces are included? 3 do you make a fuel rail with provisions for a pressure gauge? 4 how much w/ s/h? (IMG:style_emoticons/default/beerchug.gif) My late style set is perfect for conversion to front pump. You have a choice of going with just the tunnel lines (both 5/16") or the 4 pc set that includes two 5/16" engine comp. lines. Prices including shipping are $79 (2pc) or $115 (4 pc). I don't make fuel rails. IIRC many stock rails have provisions for a pressure gauge with a tee between the injector take-offs facing up and out. would the earlier lines (3/8 & 5/16) work the same? is there some advantage to smaller feed line? |
ChrisFoley |
Feb 16 2007, 04:54 PM
1 do you have a line set to convert a 73 to front pump? 2 what pieces are included? 3 do you make a fuel rail with provisions for a pressure gauge? 4 how much w/ s/h? (IMG:style_emoticons/default/beerchug.gif) My late style set is perfect for conversion to front pump. You have a choice of going with just the tunnel lines (both 5/16") or the 4 pc set that includes two 5/16" engine comp. lines. Prices including shipping are $79 (2pc) or $115 (4 pc). I don't make fuel rails. IIRC many stock rails have provisions for a pressure gauge with a tee between the injector take-offs facing up and out. would the earlier lines (3/8 & 5/16) work the same? is there some advantage to smaller feed line? The output fitting on the pump is closer to 5/16". If you go with a 3/8" line the connecting hose won't fit well at one end. The factory changed the tunnel lines to both 5/16" (8mm) when they moved the pump. |
orange914 |
Mar 12 2007, 04:04 PM
1 do you have a line set to convert a 73 to front pump? 2 what pieces are included? 3 do you make a fuel rail with provisions for a pressure gauge? 4 how much w/ s/h? (IMG:style_emoticons/default/beerchug.gif) My late style set is perfect for conversion to front pump. You have a choice of going with just the tunnel lines (both 5/16") or the 4 pc set that includes two 5/16" engine comp. lines. Prices including shipping are $79 (2pc) or $115 (4 pc). I don't make fuel rails. IIRC many stock rails have provisions for a pressure gauge with a tee between the injector take-offs facing up and out. would the earlier lines (3/8 & 5/16) work the same? is there some advantage to smaller feed line? The output fitting on the pump is closer to 5/16". If you go with a 3/8" line the connecting hose won't fit well at one end. The factory changed the tunnel lines to both 5/16" (8mm) when they moved the pump. chris 1)where exactly are the 2 other pieces located in the 4 pc set? 2)if i install the 75-6 set on my 73 are there any other mods needed to move my three port pump to the front?- can i just tee in the third (relief line) to the tank return line? 3)i relize im late in finally ordering -but- will you honor the sale price?? thanks, mike |
ChrisFoley |
Mar 13 2007, 03:35 PM
chris 1)where exactly are the 2 other pieces located in the 4 pc set? 2)if i install the 75-6 set on my 73 are there any other mods needed to move my three port pump to the front?- can i just tee in the third (relief line) to the tank return line? 3)i relize im late in finally ordering -but- will you honor the sale price?? thanks, mike 1) They go here: 2) no other mods, tee - yes. 3) That batch sold out. I'm holding the list price for now but may be raising it soon due to increased stainless prices. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:57 AM |
