Fuel Lines Buddy Sale, Through St. Valentine's Day '07 |
neo914-6 |
Feb 19 2007, 11:43 AM
Felix, I'll hold the sale price for you. What's your transplanted engine (ie. do you need a 3/8" line for a six)? Do you want just the 2 pc tunnel lines for both cars? or 4pc for your buddy. Chris, I have the Audi 2.7tt, which line size to you recommmend? I don't know what the factory line size is but I know it's high pressure. I'll take a pair while Rob will take the 4 line set up. Will send payment today. Thanks, Felix |
ChrisFoley |
Feb 19 2007, 12:05 PM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Chris, I have the Audi 2.7tt, which line size to you recommmend? I don't know what the factory line size is but I know it's high pressure. 3/8" supply should be fine. I'll take a pair while Rob will take the 4 line set up. Will send payment today. Thanks, Felix Total is $169 |
neo914-6 |
Feb 19 2007, 02:34 PM
Chris, I have the Audi 2.7tt, which line size to you recommmend? I don't know what the factory line size is but I know it's high pressure. 3/8" supply should be fine. I'll take a pair while Rob will take the 4 line set up. Will send payment today. Thanks, Felix Total is $169 PayPal's sent. Thanks! Felix |
orange914 |
Mar 12 2007, 04:04 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
1 do you have a line set to convert a 73 to front pump? 2 what pieces are included? 3 do you make a fuel rail with provisions for a pressure gauge? 4 how much w/ s/h? (IMG:style_emoticons/default/beerchug.gif) My late style set is perfect for conversion to front pump. You have a choice of going with just the tunnel lines (both 5/16") or the 4 pc set that includes two 5/16" engine comp. lines. Prices including shipping are $79 (2pc) or $115 (4 pc). I don't make fuel rails. IIRC many stock rails have provisions for a pressure gauge with a tee between the injector take-offs facing up and out. would the earlier lines (3/8 & 5/16) work the same? is there some advantage to smaller feed line? The output fitting on the pump is closer to 5/16". If you go with a 3/8" line the connecting hose won't fit well at one end. The factory changed the tunnel lines to both 5/16" (8mm) when they moved the pump. chris 1)where exactly are the 2 other pieces located in the 4 pc set? 2)if i install the 75-6 set on my 73 are there any other mods needed to move my three port pump to the front?- can i just tee in the third (relief line) to the tank return line? 3)i relize im late in finally ordering -but- will you honor the sale price?? thanks, mike |
ChrisFoley |
Mar 13 2007, 03:35 PM
chris 1)where exactly are the 2 other pieces located in the 4 pc set? 2)if i install the 75-6 set on my 73 are there any other mods needed to move my three port pump to the front?- can i just tee in the third (relief line) to the tank return line? 3)i relize im late in finally ordering -but- will you honor the sale price?? thanks, mike 1) They go here: 2) no other mods, tee - yes. 3) That batch sold out. I'm holding the list price for now but may be raising it soon due to increased stainless prices. |
d7n7master |
Apr 29 2007, 10:20 AM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hi Chris,
I installed the tunnel fuel lines and it would seem that they are too long;-) You think maybe the jackstands made my car shrink?? (IMG:style_emoticons/default/alfred.gif) What dp you suppose is the best/easiest way to trim off about an inch without removing them from the car??? Attached image(s) |
ChrisFoley |
Apr 29 2007, 11:52 PM
If the forward bend was tightened just a little they would have more clearance. I thinkyou have to pull them out to make a change.
Lo-Fi Version | Time is now: 27th April 2024 - 10:08 AM |
