Vintage Calipers from 914-6 #11, ...the very first 914-6 to leave the factory |
Eric_Shea |
Jan 31 2007, 09:55 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Well, we received the calipers to restore for #11. This is the very first 914-6 to leave the assembly line. The car was used by the factory as a demonstrator car. They loaded it with all sorts of go fast and stop fast goodies.
In the go fast department this car received a 2.0 twin plug motor. In the stop fast department we will see some odd things. I noticed a bunch of "little stuff" that you don't see every day on your standard 914-6. Let's start with the rear. These are the real deal. These are real factory 914-6/GT calipers and I would dare say the very first set. Here's some of the standout differences from your standard 914-6 or even later GT calipers. #1 - These have the 911 M-Caliper hardware for sure. The first thing I noticed was the Ribe head cap screws with the R6 head. This differs from the rounded shoulder Ribe R5 hardware used on the 914-4 and 914-6 calipers of that era. #2 The next thing I noticed was the spacers. These are the round shouldered spacers from an early rear M-Caliper of that era. Later GT and Ferrari calipers have sharp or squared off spacers that better match the caliper mating surfaces. #3 The final note (of distinction) for the rears would be the color. It seems as though these are definitely "yellow" cad plated. On other 914-6 calipers it was difficult to tell because they were so light. When we tear into them we can usually see some yellow on the mating surfaces but, again, it's very light in color. These look to be 914-4 yellow in color, meaning; very obvious. |
Eric_Shea |
Feb 14 2007, 04:38 PM
Yes, once. Simply took it to a machine shop and they extracted it. It wasn't that deep. I've had others where the head was stripped (common) and I had to cut it off and use ViseGrips to extract the remainder. Heat works well on these. I use it on "all" of the bolts etc before I attempt to even turn them. Too much at risk.
Try (extreme) heat and a reverse bit. If ruined it "may" be able to be rewelded and retapped. I think the alloy is pretty straightforward. I thought 908 pistons were the same... (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:59 PM |
