Why NASCAR is for wussies, Reprinted from rennlist |
Joe Bob |
Nov 22 2003, 09:41 AM
Why NASCAR Is For Wussies
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500. * Under full throttle, a dragster engine consumes 1-1/2 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. * A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger. * With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle. * At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture for nitromethane the flame front temperature measures 7050 degrees F. * Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases. * Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder. * Spark plug electrodes are totally consumed during a pass. After ½ way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow. * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half. * In order to exceed 300 mph in 4.5 seconds dragsters must accelerate an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's. * Dragsters reach over 300 miles per hour before you have completed reading this sentence. * Top Fuel Engines turn approximately 540 revolutions from light to light! * Including the burnout the engine must only survive 900 revolutions under load. * The redline is actually quite high at 9500rpm. * The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta). Putting all of this into perspective: You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course. That folks, is acceleration |
Nov 22 2003, 01:30 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i dunno about you guys but i like a car i can drive around corners.
left AND righthand corners .... (IMG:style_emoticons/default/driving.gif) Andy |
scotty |
Nov 22 2003, 02:13 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
F-15: accelerates and turns.... (IMG:style_emoticons/default/laugh.gif)
Brad Roberts |
Nov 22 2003, 02:14 PM
I havent taken you too a professional NHRA drag race.
Standing at the starting line with two Top Fuel dragsters staged ready to run... and both of them launch with close to 7000hp to the rear wheels making a side by side 320mph pass that blurs your vision, burns your nose and makes your hair tingle... It will ALWAYS be more exciting than any road race. B |
fiid |
Nov 22 2003, 02:22 PM
I have to say that that does blow the doors of of NASCAR.
I have heard though that the thing about NASCAR is that when those things get up to 200Mph (which I am told they do) they are basically floating. I'd like to see some of this drag racing stuff, but road racing is likely a better hobby. More to learn, and it should be cheaper. Fun fun. Fiid. |
Brad Roberts |
Nov 22 2003, 02:29 PM
Drag racing is MUCH cheaper. You can use a set of slicks for 3-4 events before they need replacing. Drag racing is much easier on the engine than road racing.
The amazing thing about Nascar... the noise the cars make at 185mph with the engine OFF. Paul Heery/his son and I watched nightime qualifying at Daytona for the Pepsi 400 from behind pit wall. They make 1 warm up lap.. then 2 full throttle qualifying passes.. on the last lap they cut the engine at over 185 mph when they cross the finish line. The car coasting at 185mph and NO other noise except the AIR coming off the car.... is LOUD. I had No idea how loud "AIR" was coming off the body panels of the car. This something you dont normally get to experience. Normally all the cars are out on the track and it sounds like a 190mph frieght train... so you dont hear the "AIR" coming off the cars like we did that night. Truelly awesome. I respect all forms of racing. I have had a hand in several different forms... it takes a ton of work no matter what form you choose. B |
Nov 22 2003, 02:30 PM
QUOTE(Brad Roberts @ Nov 22 2003, 12:14 PM) It will ALWAYS be more exciting than any road race. if you're talking about watching, you're probably right. but i still prefer road racing if i'm driving. in fact, i even take a nice, long hill-climbing event over road racing. or moto-cross (cross-country) with a good bike. anything that doesn't just make me go straight for a few 100 yeards, even if it's wicked fast. i like the challange of mastering the handling of the vehicle i'm driving. used to do cross country moto-cross when i was younger. but, everyone's different. and that's a good thing. Andy |
Brad Roberts |
Oh.. the top fuel teams use a new pair of slicks every pass.
B |
McMark |
Nov 22 2003, 02:37 PM
That whole thing kinda describes my 914 before the deer, but then I did have a 1.7 with high compression pistons. (IMG:style_emoticons/default/blink.gif)
Brad Roberts |
Nov 22 2003, 02:50 PM
Andy,
trying to keep a car straight with say 500hp on 10inch wide slicks is more work than getting any Porsche around a corner. Instead of 4 wheels with traction.. you only have two. Makes for a wild ride trying to keep a car in a lane that is 12 feet wide for 1320ft on the rear tires while it wants to skate back and forth. I'll get you in a drag car one day. I wont try and change your mind... but you have the same "vision" of drag racing that most people have. Suspension setup and tuning play the same role in drag racing as they do in road racing. Getting the rear tires to plant when being shocked with 500lbft of torque (and not going up in smoke) is a science. It will be fun.. you will see. b |
McMark |
Nov 22 2003, 03:05 PM
You mean there's more than press the pedal when the light turns green and see what happens? (IMG:style_emoticons/default/laugh.gif) What do you mean you have to step on the gas before the light turns green? (IMG:style_emoticons/default/blink.gif)
Nov 22 2003, 03:14 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
QUOTE(scotty @ Nov 22 2003, 12:13 PM) F-15: accelerates and turns.... :lol: Bullshit. The F-15 takes something like 15 seconds to run 1/4 mile from a standing stop. Just running, I can outpace an F-15 from 0 MPH to 15 MPH. The average family sedan runs better 0-30 times than an F-15. The F-15 cannot make it through any corner sharper than 1/4 mile, unless it is on the ground and almost at a full stop. Jets do not accelerate very well at low speeds. In fact, they are really awful at it. At high speeds, at high altitudes, they rule. But when placed on equal footing (so to speak) with a ground vehicle, they come off second-best. ...Not to mention that the F-16 both out-accelerates and out-turns the 15... (IMG:style_emoticons/default/biggrin.gif) It weighs less than half as much, puts out half the thrust... --DD |
scotty |
Nov 22 2003, 04:38 PM
Very true, Dave...must be the raw speed and that 3rd dimension.
I love the night drags at Woodburn...better than a thunderstorm. It'll be real interesting when electric dragsters are competitive w/top fuel (darn spooky sound-wise, too) |
GWN7 |
Nov 22 2003, 04:54 PM
F-15eens coming off a carrier are fast. Can't remember, but I think they do 150-180 mph off the deck and something like 3-4 G's in 2-3 seconds.
plus if you pissed a F15 pilot off, there wouldn't be enough of your car left to write a postcard on. (IMG:style_emoticons/default/laugh.gif) |
Curvie Roadlover |
Nov 22 2003, 05:02 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Yeah but they're powered by the carrier's catapult. They couldn't take off from the deck without it even if they started from the very back of the deck and the ship was into the wind at full throttle.
Nov 22 2003, 11:48 PM
QUOTE(GWN7 @ Nov 22 2003, 02:54 PM) F-15eens coming off a carrier are fast. Can't remember, but I think they do 150-180 mph off the deck and something like 3-4 G's in 2-3 seconds. Nope. F-15s coming off of a carrier catapult come off in pieces. They are not Navy aircraft, nor are they carrier-capable. That means that if you hook them up, the catapult will rip the plane to pieces. F-18s, now, those are indeed carrier-capable aircraft. --DD |
redshift |
Nov 23 2003, 12:13 AM
GWN7 |
Nov 23 2003, 03:22 AM
Brad Roberts |
Nov 23 2003, 05:00 AM
I love you Dave. (IMG:style_emoticons/default/wub.gif)
Sometimes I forget Dave is a NASA contrator. B |
Nov 23 2003, 08:16 AM
Lo-Fi Version | Time is now: 9th May 2024 - 10:23 AM |
