Why NASCAR is for wussies, Reprinted from rennlist |
Joe Bob |
Nov 22 2003, 09:41 AM
Why NASCAR Is For Wussies
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500. * Under full throttle, a dragster engine consumes 1-1/2 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. * A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger. * With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle. * At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture for nitromethane the flame front temperature measures 7050 degrees F. * Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases. * Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder. * Spark plug electrodes are totally consumed during a pass. After ½ way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow. * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half. * In order to exceed 300 mph in 4.5 seconds dragsters must accelerate an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's. * Dragsters reach over 300 miles per hour before you have completed reading this sentence. * Top Fuel Engines turn approximately 540 revolutions from light to light! * Including the burnout the engine must only survive 900 revolutions under load. * The redline is actually quite high at 9500rpm. * The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta). Putting all of this into perspective: You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course. That folks, is acceleration |
ArtechnikA |
Nov 23 2003, 08:44 AM
QUOTE(Dave_Darling @ Nov 22 2003, 01:14 PM) Jets do not accelerate very well at low speeds. In fact, they are really awful at it. unless of course you're talking about a full-military-thrust cat shot off a carrier deck in an F-14... |
fiid |
Nov 23 2003, 01:32 PM
I also have respect for all forms of racing. I guess what I meant was that road racing is the most interesting to me at this point (IMG:style_emoticons/default/smile.gif). I Had no idea drag racing would work out cheaper... I guessed that since your motor only really needs to run for a couple of minutes per event that they would be tweaked to the absolute limit and there would be a lot of rebuilds and stuff. Didn't know if tires would blow that cost away. I should make statements about things I know nothing about. Maybe we should do a 914club trip to a drag night over at sears??
Anyone know what the calendar is like over there. On the aero side - I think now would be a good time to bring up the JATO unit. Dave? I greatly enjoyed reading the f15 stuff. Encore! Fiid. |
PatW |
Nov 23 2003, 02:52 PM
Wassup? Group: Benefactors Posts: 565 Joined: 19-February 03 From: Rocklin, CA Member No.: 317 Region Association: Northern California |
Ok, I'll jump in..
NASCAR for wussies?. (IMG:style_emoticons/default/bs.gif) This has been hashed out before. I had the pleasure to drive with a few NASCAR Southwest Tour regulars my first time doing Indoor Karts in santa clara. Needless to say I was killed and bullied all over the track. So this year I did a few Skip Barber Schools and a bunch of Karting to be ready for them next time.. And in Sept, I still got killed again but, not as bad. I got a few handshakes and raised some eyebrows. I then found a new respect for racers that do anything with NASCAR.. Drags?. My Dad and I used to go out and watch the Autumnationals at Fremont Raceway way back when the Top Fulers were running 5.20s. You could feel the shockwave as the Top Fuler went past at something like 250mph. Oh and try to get the sound out of your ears took a week. Stood next to Bob Glidden as his car failed the min weight on the scale. Then heard hims cuss like a sailor. Watched the doors slammer class do under 11.00sec. when weaving/laying rubber all over the track. Most rememberable was a small block Nova slew a big block Buick... What I learned this year?. Its all relative, There are many diffrent disciplines to race car drivng and not all apply to each but, it still takes skill, courage, B@lls and a massive understanding of car control to be good at any of them. Too bad for me I'm just starting to figure this out. Pat |
Joe Bob |
Nov 23 2003, 03:25 PM
QUOTE(Dave_Darling @ Nov 22 2003, 09:48 PM) QUOTE(GWN7 @ Nov 22 2003, 02:54 PM) F-15eens coming off a carrier are fast. Can't remember, but I think they do 150-180 mph off the deck and something like 3-4 G's in 2-3 seconds. Nope. F-15s coming off of a carrier catapult come off in pieces. They are not Navy aircraft, nor are they carrier-capable. That means that if you hook them up, the catapult will rip the plane to pieces. F-18s, now, those are indeed carrier-capable aircraft. --DD Yeah NAVY planes are built with gnarliest landing gear around. They get retired faster than a land based plane(s).....but I've heard that the landings is what REALLY screws them up.... They land in neutral, hit the wire arrestor...hopefully....and then slam the throttles to the fire wall in case the cable snaps..... |
maf914 |
Nov 24 2003, 10:13 AM
Carrier aircraft land at a temendous angle. I've read that its called a controlled crash. Must have some great shocks!
A few days ago I heard a fighter, looked up, and saw what I thought was an F-14 Tomcat. Twin tailed, laid back. That would be unusual since there are no Naval Air Stations in the area. I see F-16's occasionally since there are Air Reserve units stationed nearby. Mike |
JWest |
Nov 24 2003, 10:25 AM
QUOTE(Dave_Darling @ Nov 22 2003, 01:14 PM) Jets do not accelerate very well at low speeds. Yes, but can your 914 do it VERTICALLY? (IMG:style_emoticons/default/ohmy.gif) And when was the last time your 914 cornered at 9G? (IMG:style_emoticons/default/laugh.gif) |
ArtechnikA |
Nov 24 2003, 10:31 AM
QUOTE(James Adams @ Nov 24 2003, 08:25 AM) ...can your 914 do it VERTICALLY? And when was the last time your 914 cornered at 9G? yes. but not up. Riverside International Raceway, October 1980. there was a wall involved ... |
JWest |
Nov 24 2003, 10:35 AM
QUOTE(mikez @ Nov 23 2003, 01:25 PM) They land in neutral, hit the wire arrestor...hopefully....and then slam the throttles to the fire wall in case the cable snaps..... Actually, they have quite a bit of power on, with lots of flaps and speed brakes to keep the velocity slow. This gives you more control response. Full AB at touchdown in case you miss the wire or the hook bounces so you can go around again. Cable brakes are rare, if they do happen someone might die from it slinging across the deck. I just had to comment - my dad flew F-4s and F-14s and I do stability and control on F-16s. |
need4speed |
Nov 24 2003, 01:52 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
QUOTE(mikez @ Nov 22 2003, 07:41 AM) . . . . * The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. . . . . I assume these guys are drug dealers in their spare time? - - - - I suspect that the A-8 Harrier can do some pretty tight turns compared to either the F-16 or F-18. I guess I'll do a little homework and see if I can't come up with the same stats for an Atlas IIAS. . . |
Joe Bob |
Nov 24 2003, 01:59 PM
Yeah the Harrier can turn on a dime with the vectored thrust.....but they can only outwait a supersonic jet like the Eagles and Hornets, hoping they run otta gas and have to RTB.....the Harrier is not supersonic.
Nov 24 2003, 05:47 PM
The technical term is "VIFF"--Vectoring In Forward Flight. Helps the Harrier turn very sharply.
The JSF won't really be able to do that (they have a separate lift fan that they can't really use very well when moving fast) but they do have a vectorable rear nozzle which will give them pretty decent agility. And it definitely is supersonic!! I forget if they were going for "super cruise" on that or not. For Rich H--the F-14 on full burner still doesn't accelerate very well at low speeds. It's the massive steam catapult that really gets it moving. Navy aircraft go through a much more thorough maintenance check than Air Force aircraft do. The Navy has (had??) some F-16s they used for OpFor (Opposition Force--the "Bad Guys") when training. In one of their regular inspections, they found that the main wing spars or supports were cracking. Yipe!! The AF found that out as well, but quite a bit later. They don't check as well as the Navy boys do. (That's why one whole series of F-16 went through truly massive overhauls. They had to replace that wing section.) I must admit that I do have a grudging respect for the NASCAR boys. I still don't think most of them are really top-caliber drivers, but they are so far above me in talent and skills that it isn't even funny. Probably the worst of them is orders of magnitude better than I could ever be in my life. But that doesn't make them world-class... And the whole attitude in a lot of this country of, "Iffin it ain't NASCAR, it ain't racin'" does tend to irritate after a while. And besides--real race cars can turn right!! (IMG:style_emoticons/default/biggrin.gif) --DD |
TheCabinetmaker |
Nov 24 2003, 05:58 PM
Dave, the Navy and Air Force do the same inspections on like aircraft. Take off and landing on a carrier cause a lot more stress than the same on the ground. The diff is, the Navy does their phased and periodic inspections with greater frequency.
TheCabinetmaker |
Nov 24 2003, 06:04 PM
Actualy, there is one thing the Navy inspects that the Air Force doesn't.
Folding wings (IMG:style_emoticons/default/laugh.gif) |
grantsfo |
Nov 24 2003, 06:08 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I think the "real" reason that NASCAR is for wussies is this:
(IMG:http://www.toyotacelicaonline.com/celica1/fastest/nascar.jpg) |
scotty |
Nov 24 2003, 06:09 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
Dave, can the JSF do the Cobra manuver that those SU's do? That was really cool at the air show...
ArtechnikA |
Nov 24 2003, 07:19 PM
QUOTE(Dave_Darling @ Nov 24 2003, 03:47 PM) For Rich H--the F-14 on full burner still doesn't accelerate very well at low speeds. It's the massive steam catapult that really gets it moving. yes, i know - it's the full afterburner thrust that keeps the aluminum cloud from simply plummeting into the ocean somewhere before it drops the full 60 feet off the deck ... |
Lo-Fi Version | Time is now: 20th May 2024 - 06:07 AM |
