best way to remove stripped rocker studs?, 2 nut trick wont work |
shaggy |
Feb 5 2007, 05:00 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
i have 3 stripped rocker studs and they need to come out so the heads can go back on!
just the top part is stripped the part in the head itself is fine. how about MAPP gas and a big pair of pilers? MAPP wont mess up the head will it? thanks -jim ps ill also need to know how to get the new studs in... |
Aaron Cox |
Feb 5 2007, 05:01 PM
vise grips.....
shaggy |
Feb 5 2007, 05:21 PM
tried it; just spin...
jd74914 |
Feb 5 2007, 05:47 PM
Weld a nut to the top of them, then take off like normal with a wrench.
shaggy |
Feb 5 2007, 05:48 PM
i dont weld or have a welder...
StratPlayer |
Feb 5 2007, 05:50 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I used vise grips they didn't spin at all, they broke the stud. Get them on as tight as you can they won't spin.
jd74914 |
Feb 5 2007, 05:52 PM
i dont weld or have a welder... Ok, then follow the way of the stratplayer (IMG:style_emoticons/default/laugh.gif) |
shaggy |
Feb 5 2007, 05:54 PM
not workin for me and i just broke a pair or vice grips trying to do it.
the lever that sits against the adjustment screw just bent and now my grips are skewed by about 1/4 inch... any other ideas? -jim |
Chris Pincetich |
Feb 5 2007, 06:37 PM
I don't have a welder either, but I have JB weld. I wonder if this would be strong enough after an overnight sit? Last time my vice grips sliped, I used a grinder to make flat spots (different hardware though) that gripped better. Good luck! (IMG:style_emoticons/default/beerchug.gif)
brer |
Feb 5 2007, 06:40 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
try going in 1/4 turn first, then out.
and soak them with aerokroil overnight |
jasons |
Feb 5 2007, 07:28 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
not workin for me and i just broke a pair or vice grips trying to do it. the lever that sits against the adjustment screw just bent and now my grips are skewed by about 1/4 inch... any other ideas? -jim Jim I have a welder, if you really need a nut welded on I could do it for you. |
jasons |
Feb 5 2007, 07:34 PM
One of these sockets is the "right" way to remove and install studs... The more pressure you put on the lever, the more this thing bites down.
This one is just an example, I don't know if its good or not. My friend has a couple that are made by Hazet. Ebay Stud Socket |
Matt Romanowski |
Feb 5 2007, 07:35 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Heat the head up and then use a pair of channel locks. That should do it. The angle of the head makes them work better than vice grips. If you have pliers that are shaped like channel locks that don't slide, those work really well.
Or you could just buy a stud remover.... |
Krieger |
Feb 5 2007, 07:38 PM
Advanced Member Group: Members Posts: 4,712 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Also, take a punch/hammer and tap on it a few times. Soak it with penetrent. This may sound counterintuitive but try to tighten it a little then loosen, tap tap tighten loosen. Carefully heat the head with a torch or put it in the oven @ 250 for 15 minutes. The aluminum expands more than the steel.
SGB |
Feb 5 2007, 07:45 PM
Sounds really really tight. HEAT is the thing I think. Days and days of pb or some penetrant, heat, more wd blaster/wrench, etc. If you are distorting things as much as you say, that can't be good. Is it too late to try to cut new threads on the stud? Smaller than original might be OK. Is there no place for the nut to get any grip? I guess that vice gripping prolly did quite a number on 'em, but it may have moved some metal into previously smoothed areas....
Overall, I'm sorry but I'll bet it can't be done without some pretty major machinery. I'm sure Len Hoffman (Jakes head guru- or is that "head" head guru), could tell ya. |
jd74914 |
Feb 5 2007, 08:37 PM
Jason has a good idea. If you get the forged craftsman sockets that bite into stripped studs and bolts you will be set. Those and heat take out even the most stubborn things.
spare time toys |
Feb 5 2007, 08:41 PM
This is how I got the exhaust studs out of the 928 head. They were stuck to where a vice grips would slip. One of the old engine guys at work told me about paraphin wax. Heat the head good and hot and rub the wax around the base of the stud. The wax will wick down the threads and it will come out with no trouble. I went to Albertsons got the canning paraphin and melted and formed a stick out of it when it hardened. I took just a plain old beutaine torch heated the head and rubbed the base of the stud. I could watch it draw the wax in. I grabbed it with the vicegrips and it turned out with out a hitch. I did 15 of my 16 studs that way. #16 was broken off BELOW flush. That one is another story for another thread.
-Larry |
URY914 |
Feb 5 2007, 08:44 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
This is how I got the exhaust studs out of the 928 head. They were stuck to where a vice grips would slip. One of the old engine guys at work told me about paraphin wax. Heat the head good and hot and rub the wax around the base of the stud. The wax will wick down the threads and it will come out with no trouble. I went to Albertsons got the canning paraphin and melted and formed a stick out of it when it hardened. I took just a plain old beutaine torch heated the head and rubbed the base of the stud. I could watch it draw the wax in. I grabbed it with the vicegrips and it turned out with out a hitch. I did 15 of my 16 studs that way. #16 was broken off BELOW flush. That one is another story for another thread. -Larry Now that is slick....learn somein' new everyday around here. |
PinetreePorsche |
Feb 5 2007, 10:14 PM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
Did this on my old split-window van decades ago: use a little cut-off wheel on a Dremmel-type grinder to make a clean screwdriver slot across the stud. Warm the head in the oven,, using penetrating oil before and again when hot (outdoors for this), then go at the screw slot with an impact driver,. with blade not too long for the slot--ground shorter if too long. Build up the blows from not too hard to harder, and, like someone said, reverse the direction of the driver every 3 or 4 blows. It's gotta go. If not, drill in all the way and use easy-outs--not easy, but what else can you do?
Lo-Fi Version | Time is now: 18th May 2024 - 02:25 PM |
