Moving Battery, Moving Battery to front |
xperu |
Feb 6 2007, 06:21 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I want to move my battery to the front of the car, please give me some direction on the best way to run the cable through the car, the gage of cable and the best way to mount the battery. Thanks Mike
tdgray |
Feb 6 2007, 07:23 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
I purchased a battery relocation kit from Jegs. Came with a plastic box cable etc. I ran my cable on the inside of the rockers into the trunk.
I did have to make my own mountings though... I think there are pics of it in my progress thread. Look at the signature for the link. |
xperu |
Feb 8 2007, 06:34 AM
John |
Feb 8 2007, 11:41 AM
I used welding lead. It's oversized to be sure, but I know it is more than capable of carrying the amps. I ran my cable under the fuel tank, through the center tunnel and around the engine with the rest of the original harness. I exited the engine compartment at the drivers side rear and then goes directly to the starter. I extended all the other large gauge red leads up to the front to connect directly to the battery positive terminal. (I suppose I could have landed them at the starter terminal and saved some wire.).
I put my battery in a plastic marine case. (I'm too cheap for the Optima battery) Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 01:54 PM |
