combustion chamber anomaly...crusty lava rocks, what is it and why is it there? |
sean_v8_914 |
Feb 6 2007, 12:28 PM
2.0 D-jet with 5000 miles
notice how it is in teh upper third by the plug. nothing near the OD it is crusty. looks like lava rocks in the middle the head did not leak, pic is deceiving Attached thumbnail(s) |
sean_v8_914 |
Feb 6 2007, 12:29 PM
the back of the piston has brown varnish stain
SLITS |
Feb 6 2007, 12:30 PM
Mainly deposits from shitty gas additives & some burnt oil. Not a problem ... clean it and reassemble.
Ok, so you posted a second image ..... I might take exception about the head leaking, but the photos are Ahandiesque that it is hard to tell. |
sean_v8_914 |
that light spot is where I picked off a chunk
Rusty |
Feb 6 2007, 12:31 PM
Carbon build-up.
Running rich, probably. Burning oil, maybe? Looks like you might have had an oil leak there... cylinders not well sealed to the case. Good thing you caught it. (IMG:style_emoticons/default/smile.gif) |
sean_v8_914 |
Feb 6 2007, 12:33 PM
I think it was an event rather than an ongoing accumulation
any complaints about ARCO gas? I have been running 91. it pings a bit on 87 |
sean_v8_914 |
Feb 6 2007, 12:34 PM
the oily drool marks are from washing the outside prior to disassembly
sean_v8_914 |
Feb 6 2007, 12:35 PM
teh oil filler neck was leaking and caused a mess
PS. the motor always runs great(not right now while in pcs) |
sean_v8_914 |
Feb 6 2007, 12:39 PM
the plugs have always read lean...coffee cream brown with slight ashy white-ness
sean_v8_914 |
Feb 6 2007, 12:41 PM
the photos were taken by a German (H.M.)
SLITS |
Back in the days Shell was the worst for similiar deposits .... the deposits would be white / grey if it were additives alone called ash deposits. Remember, you live in a state where to produce clean air out of vehicles and especially during the winter enough additives are added to fuel to choke any engine. It doesn't make the gas better, it just pleases the tree huggers, legislators and oil companies.
The brown on the back of the piston is normal with overheated oil. |
Dr. Roger |
Feb 6 2007, 12:43 PM
second vote for crappy gas.
I used to work for a test fuel additive lab and that looks like it. I'd run that tank empty, put some techron high grade in with an injector additive, then run 76 high grade daily IMHO. Unless you have some unocal blue gas in your state. that shtuff was a top performer back when we were rating different fuels. |
SGB |
Feb 6 2007, 01:02 PM
Roger-
what type of gas do you use? There really is a difference? Hey, I have those aftermarket compression raising devices, too! I have been having 'em incrementally installed (apparently, b/c I buy CSOB gas). |
Dr. Roger |
Feb 6 2007, 04:29 PM
I use chevron or an additive for cleanup. techron is sold to other oil companies and sold under other names. its about the best stuff on the market. I like to run something with methanol for daily driving (76 gas).
Lo-Fi Version | Time is now: 18th May 2024 - 04:51 PM |
