sean_v8_914
Feb 6 2007, 12:28 PM
2.0 D-jet with 5000 miles
notice how it is in teh upper third by the plug. nothing near the OD
it is crusty. looks like lava rocks in the middle
the head did not leak, pic is deceiving
sean_v8_914
Feb 6 2007, 12:29 PM
the back of the piston has brown varnish stain
SLITS
Feb 6 2007, 12:30 PM
Mainly deposits from shitty gas additives & some burnt oil. Not a problem ... clean it and reassemble.
Ok, so you posted a second image ..... I might take exception about the head leaking, but the photos are Ahandiesque that it is hard to tell.
sean_v8_914
that light spot is where I picked off a chunk
Rusty
Feb 6 2007, 12:31 PM
Carbon build-up.
Running rich, probably. Burning oil, maybe?
Looks like you might have had an oil leak there... cylinders not well sealed to the case.
Good thing you caught it.
sean_v8_914
Feb 6 2007, 12:33 PM
I think it was an event rather than an ongoing accumulation
any complaints about ARCO gas? I have been running 91. it pings a bit on 87
sean_v8_914
Feb 6 2007, 12:34 PM
the oily drool marks are from washing the outside prior to disassembly
sean_v8_914
Feb 6 2007, 12:35 PM
teh oil filler neck was leaking and caused a mess
PS. the motor always runs great(not right now while in pcs)
sean_v8_914
Feb 6 2007, 12:39 PM
the plugs have always read lean...coffee cream brown with slight ashy white-ness
sean_v8_914
Feb 6 2007, 12:41 PM
the photos were taken by a German (H.M.)
SLITS
Back in the days Shell was the worst for similiar deposits .... the deposits would be white / grey if it were additives alone called ash deposits. Remember, you live in a state where to produce clean air out of vehicles and especially during the winter enough additives are added to fuel to choke any engine. It doesn't make the gas better, it just pleases the tree huggers, legislators and oil companies.
The brown on the back of the piston is normal with overheated oil.
Dr. Roger
Feb 6 2007, 12:43 PM
second vote for crappy gas.
I used to work for a test fuel additive lab and that looks like it.
I'd run that tank empty, put some techron high grade in with an injector additive, then run 76 high grade daily IMHO.
Unless you have some unocal blue gas in your state. that shtuff was a top performer back when we were rating different fuels.
Roger-
what type of gas do you use?
There really is a difference?
Hey, I have those aftermarket compression raising devices, too! I have been having 'em incrementally installed (apparently, b/c I buy CSOB gas).
Dr. Roger
Feb 6 2007, 04:29 PM
I use chevron or an additive for cleanup. techron is sold to other oil companies and sold under other names. its about the best stuff on the market. I like to run something with methanol for daily driving (76 gas).
