911 engine code, Where is it? |
Justinp71 |
Feb 8 2007, 12:49 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Okay I've looked all around my 2.7L CIS motor and I can't find the engine code that identifies if it is an "s" motor or not... Does anyone know an easy way to Identify if it is an s motor, The sticker on top says 1974 911T/911S.
ArtechnikA |
Feb 8 2007, 05:32 AM
the engine Type code (911/xx) is found on the horizontal surface of the case to the immediate right of the fan housing. behind the chain housing - the chain housing is not the case... they are never stamped very deep and are usually obscured by years of crud that must be scraped/wiped away first.
The Type Code is the fastest way of telling you what the engine was when the factory built it. What it is now depends as much as anything on the budget and reputation of the builder.. |
Justinp71 |
Feb 8 2007, 11:06 AM
the engine Type code (911/xx) is found on the horizontal surface of the case to the immediate right of the fan housing. behind the chain housing - the chain housing is not the case... they are never stamped very deep and are usually obscured by years of crud that must be scraped/wiped away first. The Type Code is the fastest way of telling you what the engine was when the factory built it. What it is now depends as much as anything on the budget and reputation of the builder.. Is this on the top side of the motor? Is it visible with a fully assembled motor in the car (or even worse the tight engine compartment of a 914)? I guess I'll find out when I get home for the day. |
ArtechnikA |
Feb 8 2007, 05:19 PM
Is this on the top side of the motor? QUOTE Is it visible with a fully assembled motor in the car (or even worse the tight engine compartment of a 914)? I believe so; probably no more difficult than a 911...Follow the red pen... it points directly to my 911/43 Type Code. Attached image(s) |
Justinp71 |
Feb 8 2007, 05:23 PM
Man I looked at that area last night... I'll look again closer. I also heard that if you have a green shroud that means that you have an 's' motor... according to rennshift... not sure if that is true.
ArtechnikA |
Feb 8 2007, 05:31 PM
I also heard that if you have a green shroud that means that you have an 's' motor... according to rennshift... not sure if that is true. shroud colors changed a bit through the years, but I don't think green was ever 'S'. (But I have pretty low confidence in that statement, so if it's wrong, you're welcome to post all the right stuff of all the colors from 1965 on - but don't rub it in my face :-) ) Not for nothing is red Krylon called "S-motor in a can" ... |
Joe Bob |
Feb 8 2007, 05:38 PM
It's real FAINT......
Trust me it's there.... |
sixnotfour |
Feb 8 2007, 06:05 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Is there a number on the vertical surface to the left of the oil pressure sender, in the picture ?
It is possible it is an unumbered replacement case. |
ArtechnikA |
Feb 8 2007, 06:18 PM
Trekkor |
Feb 8 2007, 06:53 PM
Justinp71 |
Feb 8 2007, 08:17 PM
Found it... its a 911/44, which according to wayne's book that is a 911s/c Which i am assuming a 911s motor for california. Which still has the 8.5:1 pistons but I guess it was smogged down to 160hp.
Joe Bob |
Feb 8 2007, 08:21 PM
Found it... its a 911/44, which according to wayne's book that is a 911s/c Which i am assuming a 911s motor for california. Which still has the 8.5:1 pistons but I guess it was smogged down to 160hp. 911 but not an SC....SC started in 78 and used the 930 engine block.... |
ArtechnikA |
Feb 8 2007, 08:25 PM
not "911SC"
911S - California. My 911/43 is a '75 S - 49-State. 5 HP difference - woo hoo. |
Justinp71 |
Feb 8 2007, 09:45 PM
not "911SC" 911S - California. My 911/43 is a '75 S - 49-State. 5 HP difference - woo hoo. Correct, but with my wierd straight pipe exhaust who knows.... Does that oil pressure switch which next to the engine code run the factory "Druck pressure" gauge, I tried to hook it up my the gauge defaulted to max press. |
SLITS |
Feb 8 2007, 10:10 PM
Does that oil pressure switch which next to the engine code run the factory "Druck pressure" gauge, I tried to hook it up my the gauge defaulted to max press. Druck = pressure If your guage pegged, the wire between the guage and sender is grounded or the sender is bad. |
ArtechnikA |
Feb 9 2007, 04:46 AM
Does that oil pressure switch which next to the engine code run the factory "Druck pressure" gauge, I tried to hook it up my the gauge defaulted to max press. yes, that's the pressure sensor for the gauge. we need to know more about what you mean by "the" factory gauge, tho, since 914.6 didn't have one, and 911's had at least two kinds. early cars get a 10 Bar gauge, later cars get a 5 Bar gauge, and the senders are different and don't play together. But as Slits has pointed out, fullscale typically means the gauge is not wired properly (they need +12V, good ground, and the gauge signal, all on the correct terminals) or that something is not connected correctly - fullscale is where Bosch/VDO gauges go when the G(uage) line is open. it's also what I'd expect if the gauge is actually connected to the pressure switch for the oil pressure light... Since 914's (4 or 6) had no gauge originally, if your car has one, someone has been creative with the wiring, so that's the first thing to check. You also need to research to make sure you have the right sender to go with the right gauge. |
Justinp71 |
Feb 9 2007, 10:40 AM
My gauge looks like the one in the pic. It says '81 on the back and I believe that my sending unit is an original '75 911 sending unit, Which is a different one than the gauge. But I also tried to hook up an aftermarket vdo gauge and I got the same result...
Justinp71 |
Feb 9 2007, 12:47 PM
Also.. let me clarify... the gauge has not been installed yet, I would like to install it.
I also have to figure out what to do for a fuel gauge. Will an aftermarket VDO fuel gauge work (0-90 ohms)? |
ArtechnikA |
Feb 9 2007, 05:11 PM
Also.. let me clarify... the gauge has not been installed yet, I would like to install it. yes - that's the 5-Bar gauge. the sender is a variable resistance that pulls gauge +12 down to an indicated value. if the wire to the sender is open, the gauge reads full scale. (and if the wire is shorted to ground, the instrument will be pegged at minimum. I also have to figure out what to do for a fuel gauge. Will an aftermarket VDO fuel gauge work (0-90 ohms)? I believe you'll find (i don't recall exactly...) the Porsche sender is ~0-200 Ohms. There should be no lack of Porsche fuel gauges tho, and they're all about the same. you can replace just the fuel gauge part... |
Lo-Fi Version | Time is now: 18th May 2024 - 03:07 AM |
