| PRS914-6 |
Feb 11 2007, 11:09 AM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I'm building a 915 tranny in my spare time and just got the machining done for the R&P flop.
The speedometer pickup will have to be machined into the side of the side cover. Unfortunately, it will not be nearly as close to the magnetic ring as original. Anyone done this with success? |
| GeorgeRud |
Feb 11 2007, 03:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
We did machine a pickup point on the side cover of my 915 by dremeling away part of a stiffening rib, and flattening the cover to mount the pickup. We safety wired the pickup onto the adjacent ribs, and it's worked fine. You do have to have a pretty strong signal through the case to pick up the magnetic pulses, but it's been working fine. I used the quarter sized pickup, I believe the later ones are smaller.
I believe it would be easier to get an aftermarket billet side cover that would be easier to machine, but mine works nicely. |
| PRS914-6 |
Feb 11 2007, 04:00 PM
Thanks George. Really don't want to buy a billet cover. The thrust is in the opposite direction and I feel the billet is a waste of money.
What I was thinking was to filll a small area around the fins with Devcon metal filler. Then set it up in the milling machine and machine an area just like original. However, the distance will be about twice as far to the magnets as the original side. It sounds like it still works though and that is good news. |
| dflesburg |
Feb 11 2007, 04:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
pictures!!! pictures!!! pictures!!!
| dekman |
Feb 11 2007, 04:40 PM
Member ![]() ![]() Group: Members Posts: 458 Joined: 12-December 04 From: Ojai,CA Member No.: 3,274 Region Association: None |
Just did a 915Wevo with billet side cover with speedo mount(wimped out...cover was about $300). Will try to load pic's........good luck! (IMG:style_emoticons/default/clap56.gif)
| Aaron Cox |
Feb 11 2007, 05:07 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
dekman,
did you have to add the extensions on your muffler to clear the wevo? |
| Joe Bob |
Feb 11 2007, 05:08 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
I'm building a 915 tranny in my spare time and just got the machining done for the R&P flop. The speedometer pickup will have to be machined into the side of the side cover. Unfortunately, it will not be nearly as close to the magnetic ring as original. Anyone done this with success? As one who was just helped break one off during a 911 instal....can't you use the stock 915 drive and then hang an adapter off the end? BTW...do you are Dekman have an extra 915 nose cone that you want to sell? |
| PRS914-6 |
Feb 11 2007, 06:37 PM
Mike, don't understand your question. Are you talking mechanical speedo?
Here is a pic of the ring gear swapped and a stock cover. Note the thrust is now towards the solid part of the case unlike using it in a 911. ![]() ![]() |
| Aaron Cox |
Feb 11 2007, 06:40 PM
i think mike meant... why not use the mechanical sender to provide an electronic signal? still need some sensor/adapter thing..
| PRS914-6 |
Feb 11 2007, 06:42 PM
And here is how the speedo pickup is recessed in the case (stock)
| PRS914-6 |
Feb 11 2007, 06:54 PM
| East coaster |
Feb 11 2007, 08:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,931 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None
I still need to do this to my car.
It would be nice to have a speedo (not the marble sack type). |
| dekman |
Feb 11 2007, 10:21 PM
Aaron = yes. "Z" = yes.
| John |
Feb 12 2007, 12:30 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Do you have any pics showing what had to be done to the case to flip the ring gear.
I'm interested to see what exactly needed to be done. Thanks. |
| PRS914-6 |
Mar 10 2007, 08:25 PM
OK, I machined my side cover and pressed in a cup to receive the sensor. It was a lot of work but free....The sensor is now exactly the correct distance from the magnets.
Here are a few pics.... In the lathe ![]() Cup made with .004 press fit. ![]() The finished product ![]() ![]() |
| McMark |
Mar 11 2007, 09:37 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Awesome solution! (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/thumb3d.gif)
Lo-Fi Version | Time is now: 2nd May 2026 - 06:14 AM |
