Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Kevin got you on the doors, got me on one window and one regulator. Be sure and weigh old and new so the 914 world will have hard data on how much weight you lost. I'm guessing 19 lbs. per with no glass or regulator. Wanna start a pool?
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
What is that other thing in your trunk on the left side?
Porsche Rescue |
Since I'm sure you're dying to know, and JP won't be at his puter for a few hours, I'll answer. He calls it his "puke bottle". Breather hose from oil tank is connected to it. Container is very high tech. Once held candy from Costco. Nothing but the best for JP.
DrifterJay |
I break stuff... ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None ![]() |
what is the benefit of the "puke bottle" The hose on mine is cut pointing at the ground. Is the hose like an overflow thing anyways? Speaking of the hose, it is the one coming out next to the oil filler that is routed to his trunk anyways, right?
Porsche Rescue |
He'll have to give you the details. I think it is the one nearest the filler. On a stock six with carbs it goes to the air cleaner to allow the oil vapor to be sucked through the intake. Vented to the ground or engine compartment can create a bit of a mess.
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Jim's got it right, cept the jar contained mixed nuts.....seemed appropraite (IMG:style_emoticons/default/smile.gif)
He's also right bout the routing, off the filler neck to the trunk puke can....the engine crankcase is vented to the oil tank. For a futher explaination: For a street machine, it's not really required. Venting to the carbs works. I've seen the venting done to a breather filter right off the neck to the engine room.....that gets messy. My puke can stays dry durring normal use. For more strenuous use,the catch tank becomes required. Rather than carryng just mist from the crank case, it often carrys "lumps". With high G forces, the stock tank allows the oil to slosh around...even tho it's baffled. Couple that with the greater air movement from the crankcase at high rpms, oil lumps get blown into the catch tank. Prolly some aeration going on in there, also, increasing the volume I've overflowed the thing....and it will hold more than a quart. I've found if I keep the oil level half way between the dipstick marks, I'll get a couple Oz. in it after 4-5 AX passes. Either way, you don't want that much going thru the carbs or injection system. Prolly more than you wanted to know, eh? |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
JP, good info.
Venting to the ground may be okay for a street car (I've done it with my T4 without seeing any signs of liquid being spit out), but most competition rules require a catch can to prevent oiling of the track. Mike |
DrifterJay |
well than I guess I have one more thing to do before my first autox..
Jared |
J P Stein |
QUOTE(DrifterJay @ Nov 25 2003, 08:00 AM) well than I guess I have one more thing to do before my first autox.. Jared Well........ The catch can stayed dry during my first season or 2 of AX. (IMG:style_emoticons/default/laugh.gif) As "things" progressed,.....I came home from one and here's all this oil in the catch tank....WTF? Another odd ball lesson in "unintended consequences". Early this last season, it was catching lots of oil.... A bit alarming till I figured out what was going on and learned to deal with it. |
Lo-Fi Version | Time is now: 31st July 2025 - 06:33 AM |
