Headers and heaters |
FEF |
Nov 24 2003, 10:24 AM
Newbie Group: Members Posts: 19 Joined: 31-August 03 From: Oregon Member No.: 1,094 |
Forgive my ignorance. While I'm not new to vehicluar mods, I'm finding that the 914 is a bit different.
I couldn't help but notice the header thread that's a few pages back. It shows a number of pictures of some sweet headers that I may not be able to live without. The one I like mose is the Tangerine Header. As with any vehicle build, one must ask what the vehicle will be used for. In my case, it's a daily driver so defrosting and heating is fairly important. The question is, are there any headers that can have good strong heating? What header would you all recommend for someone that wants a quality unit that will later support, perhaps, a big bore kit, while still maintaning acceptable defrosting. I'm trying to buy stuff that I can grow into. I'm not afraid to spend $1000 on the good stuff, if I don't have to do it twice. Thanks in advance |
3d914 |
Nov 24 2003, 11:00 AM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I could be wrong on this, but I don't believe there are any headers (short of custom) that include the "heater boxes" required for the 914's to get heat into the cockpit.
Good luck, |
Joe Bob |
Nov 24 2003, 11:05 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Headers replace heater boxes......Bursch makes an extractor system that bolts to the heater boxes and gives a scavenging effect that improves performance on cars that had the later systems that had cat pipes....but I have told that the stock 73-74 HEs with the stock muffler works the best if you need heat.
Bleyseng |
Nov 24 2003, 11:07 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Stock SSI units with a Bursch or Triad is gud and has heat. No header unit so far has heat.
Geoff (IMG:style_emoticons/default/welder.gif) |
Joe Bob |
Nov 24 2003, 11:09 AM
SSIs are stainless copies of the 73-74 Heater boxes.....aka HEs or heat exchangers....
FEF |
Nov 24 2003, 01:04 PM
I suppose another option might be a gas heater from an old VW bus. I think they had a gas fired heater, maybe made by Webasto or Espar? I have a diesel fired unit in my U1100. Given my experiance with Webasto and Espar, they will do VERY well in this application.
In theory, one could use any pipe they wanted and add a gas fired HE for heat and defroster. I'll have to look into this a bit more. Since I plan to cut out some of my trunk, there should be plenty of room for things like this. Right now, I'm thinking something like THIS might be the ticket. That is the diesel version, but it's equilivent in specs to the gas unit. The more I think about it, I like the idea of a seperate heater unit a lot. |
Dave_Darling |
Nov 24 2003, 01:08 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think the original heaters on the Bugs and Buses were Webasto or Eberspacher. From what I have read, they are somewhat non-trivial to hook up to a 914 reasonably.
Some people have used electrical heaters. From the sound of it, they can usually defrost a window but they won't heat the cabin very well without putting a huge drain on the battery. The rumor mill has mentioned something about Chris at Tangerine possibly making a revised version of his header that has some heat-exchanger ducting wrapped around part of it. But right now, if you need heat then you need SSIs. --DD |
ChrisFoley |
Nov 24 2003, 05:13 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
As a matter of fact I was working on the second and third prototypes of my heat exchanger/muff today. The first one ships out this week with the header I built it for.
Here's another pic of the first prototype: Attached image(s) |
r_towle |
Nov 24 2003, 05:17 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I was gonna say, Chris makes em with heat now!!!!! (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/boldblue.gif)
Now i'll get one,,,gotta get the frost off the winshield in the morning... Chris your pic isnt there??? Rich |
DuckRyder |
Nov 24 2003, 05:19 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Picture no worky,,,,,,,,,,,,,,,,
FEF |
Nov 24 2003, 05:55 PM
HUMmmmmmmm
So I can get a Tangerine header with the heater box on it??????? That sounds just too easy. |
ChrisFoley |
Nov 24 2003, 06:28 PM
QUOTE(FEF @ Nov 24 2003, 06:55 PM) HUMmmmmmmm So I can get a Tangerine header with the heater box on it??????? That sounds just too easy. Not only that, but you can install/remove the heater by yourself without much work. You could buy the header and heater separately and they will still fit together easily. (IMG:style_emoticons/default/smile.gif) No (IMG:style_emoticons/default/smash.gif) |
DuckRyder |
Nov 24 2003, 06:48 PM
Dammit, This car has got to leave my garage or I will be broke.................................................... (IMG:style_emoticons/default/chair.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 08:12 AM |
