How in the hell do i get that goddamn circlip, out of the top of the dizzy shaft? |
nebreitling |
Nov 24 2003, 08:38 PM
it's dizzy rebuild time. never done this w/ the 914. does anyone have any advice on how to get that goddamn-little-bitty-itsy-bitty circlip out of the top of the distributor cam shaft? i've tried swearing. that didn't work.
i assume this is necessary in order to extract the weights down below. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) thanks nathan |
Brad Roberts |
Nov 25 2003, 12:26 AM
I'm pretty sure I use a very small flat blade screwdriver to pry it over.
For some reason.. I dont recall having to pull that piece out.. Why are you pulling the dizzy apart ?? I thought you had bad trigger points ?? Truelly rebuilding the dizzy requires shaft/bearing replacement. B |
nebreitling |
Nov 25 2003, 12:45 AM
yeah, i know i don't have to do this just to replace the FI points.
but after opening, it needs a thorough cleaning. the weights are still moving around nice and freely, but there's a bit of surface rust and corrosion. as long as i had it out, i thought i'd clean it up nice n purty. the bearings are still good (no side-to-side movement at all), so i wasn't going to go all the way. just to 3rd base. (IMG:style_emoticons/default/cool.gif) i'm about to give up on this, though; i don't have a small enough tool to get the damn thing out... to tired to invent something. re. the FI points, they don't look great, but they are opening and closing properly and making good electrical connections (checked continuity with my multi-meter). i'll still replace them, but now i'm dubious that this is the problem. now i'm wondering if my problem isn't in the FI harness. (IMG:style_emoticons/default/confused24.gif) we'll see. i'll go ahead and FINALLY install that crane xr700 while i'm at it. thanks brad, happy b-day again n (IMG:style_emoticons/default/aktion035.gif) |
Brad Roberts |
Nov 25 2003, 01:11 AM
The trigger points can work in your hand and not work at 2k RPM.
Thanks for the B-day wish. Thankfully it was uneventful besides the yelling from wife. b |
Lo-Fi Version | Time is now: 9th May 2024 - 02:07 AM |
