3 Pages V < 1 2 3
> Purchasing 914 V8...opinions?
slothness
post Mar 20 2007, 05:30 PM
Post #41
It's business time
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
michaelt55
post Mar 20 2007, 05:52 PM
Post #42
Graduate of Life's experiences
photos will be posted when I place it in the classified area....and all particulars...
Michael
sirnose
post Mar 21 2007, 05:54 AM
Post #43
Congrats on the purchase. Check http://v8buick.com/ in the small block threads for details on the engine and I've got a list of more sites if you want them. It's not a bad motor although I did lose a valve seat on my '74 Range Rover's motor.
I'm just getting started on my v-8 conversion - originally intended to be a buick/rover stroker. Then I came across a complete running 928 4.5 for cheap (guy's doing a Chevy conversion) and have been researching that after looking at Rick's alien build. I really like the idea of keeping it all Porsche. (IMG:style_emoticons/default/aktion035.gif)
But today, as always when I don't have the disposable income, I got offered a built Buick 215 (stroked to 266 ci with Buick 300 aluminum heads, Buick 300 crank, TA Performance cam & roller rockers, Holly 390 carb & Edelbrock intake, Kennedy adapter, etc). I can pick it up cheaper than what it will cost me to finish with the parts I've already collected (Rover 4.0 block x-bolt block & injection manifold plus Buick 300 heads & crank). Finishing with the parts I've got now will run another $5k -more than twice the price of the already built engine. (IMG:style_emoticons/default/headbang.gif)
Rick, want to trade parts for parts? I'd seriously think about trading the block, heads, crank etc I have for some of your original 928 stuff (mounts, etc.). (IMG:style_emoticons/default/sawzall-smiley.gif) Or do you want the alien to be an only child?
jimkelly
post Mar 21 2007, 07:46 AM
Post #44
Delaware USA
this is pretty much what eric shea told me recently - good work - jim
i'm doing a v8 and will keep stock brakes and narrow wheels - street use only.
QUOTE(rick 918-S @ Feb 27 2007, 12:01 PM) *
The brake topic has been discussed many times. Stock brakes are fine even with a V8 under normal driving conditions with stock width and diameter tires. But when you increase the rotational mass with larger diameter tires and a larger contact patch it takes more clamping force to counter the added rotational forces. If you don't increase the tires and wheel size you will just smoke the stockers. Hence to need for the brake upgrade.
65 mph is 65 mph whether you have a 4 cylinder, 6 cylinder or a V8. If you have a 4 cylinder with a passanger and a V8 without you have approximately the same weight vehicle. All things the same you should have the same car.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 8th July 2025 - 07:28 PM
