ignition switch and fuel pump |
Steve Thacker |
Nov 25 2003, 08:35 AM
UMMMPH Yea Baby Yea ! UMMMPH Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
I have a wierd issue maybe one of you know what is happening. I have a intermitant fuel pump problem. I was wondering if the ignition switch has anything to do with it? I know dumb question, but I have to ask. 95% of the time I turn the key to the on position. I hear the fuel pump kick in for its 1.5 sec prerun. Here lately that has not been the case. I hard wired the pump up to the fuse box to test the pump's consistant functionality, All is ok in that dept. Would a bad or going bad ignition switch cause this symptom?
Thanks!!!! |
r_towle |
Nov 25 2003, 09:23 AM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Replace the fuel pump relays and the fuses in the control box, drivers side engine compartment...
One of the fuses and one of the relays is for the fuel pum, forget which one... The fuses do very frequently jiggle loose...also the relays are quite old and due to moisture etc, they need to be replaced every 20 years or so... All parts are cheap. Rich |
SirAndy |
Nov 25 2003, 12:36 PM
Resident German Group: Admin Posts: 41,649 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
check the relay first. clean the contacts on the relay and the socket (disconnect battery to do so) ... if the relay seems to wiggle in the socket, pry the pins out a bit to give it some preload. move relays around to check, they're all the same, you can use them in any socket. you can also use your headlight relays for testing, they're the same also. later, Andy |
Lo-Fi Version | Time is now: 20th May 2024 - 05:22 AM |
