Where is the best deal for 40mm weber kit, Newbie ??? on carburetors |
timecop369 |
Nov 25 2003, 04:16 PM
Newbie Group: Members Posts: 20 Joined: 24-November 03 From: San Jose, CA Member No.: 1,383 |
Hi All,
Newbie question. I'm sure it's been asked before but I did use the search and couldn't find it. I have a 1974 2.0L slant-nose. It was running last year and now it doesn't start. I think the ECU is dead... it's not sending a signal to my fuel pump (fuel pump works). So I was thinking of putting dual weber 40mm complete kit into it and run a line from the key ignition directly to the fuel pump. I am on a limited budget (under $500). Does anyone know where I can get dual weber or dellarto carbs for an affordable price, and still have some change for lunch? Thanks in advance, timecop369 Attached image(s) |
FEF |
Nov 25 2003, 04:24 PM
Newbie Group: Members Posts: 19 Joined: 31-August 03 From: Oregon Member No.: 1,094 |
I must hi-jack the thread.....
Where can I get some of those fenders and rear quarter panels? Sheetmetal? Fiberglass? I love the look... Very sharp, indeed. Sorry for the hi-jacking. (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/cool.gif) |
Brad Roberts |
Nov 25 2003, 04:26 PM
hey man.. nice car.
Lets fix the fuel pump issue. I'm betting its the relay or the fuse. I'll be in San Jose Saturday and can look at it for a modest fee (6 pack of Pepsi) Not sure if you know where the Egytpian Mueseum is near the Rose Garden.. but I will be in that general area. B |
Brad Roberts |
Nov 25 2003, 04:27 PM
I *think* Rayco still sells the kit. Its a little updated from his kit.. but not much.
When installed correctly.. they look nice. Most people dont install them correctly. B |
Brad Roberts |
Nov 25 2003, 04:29 PM
Cant say I never helped you..
Company: Rayco, Inc. Comments: A re-body for the 914 Porsche. Address: 1710 Delmar blvd. St. Louis MO 62103 Country: US Phone 1: 314-+32-1321 Phone 2: , 314-741-7818 Fax: 314-621-1321 E-mail: n/a Website: n/a -------------------------------------------------------------------------------- Name: 986 Porsche 109 Kit: Yes Turnkey: Yes Donor: Porsche Engine Options: Several options, stock to V8 Notes: Stock front and rear suspensions, stock chassis. Influence: 914 Updated Re-body Company Remarks: |
sj914 |
Didn't that used to be called the Chalon body kit.
Brad Roberts |
Nov 25 2003, 04:30 PM
Correct.. Rayco made it.
B |
sj914 |
Nov 25 2003, 04:36 PM
I thought it was made by someone else.
As far as the webers, I had them on my previous car a '72. Unless you like tinkering with the idle settings every couple weeks I'd just go and try to fix the FI problem. Also converting to webers gets expensive. You have to change the cam if you want good performance and I don't think you can do it for 500.00 or less. |
redshift |
Nov 25 2003, 04:39 PM
You can probably get your injection up to snuff to half as much as you want to spend.... probably.
M |
timecop369 |
Nov 25 2003, 04:43 PM
Wow, quick responses! I love this forum.
Yah, Brad, I found out about this forum through Felix. He recommended me to ask you how & where to get the best deals on the carbs. It would be great if you have time to look at it this Sat. and give me suggestions or can troubleshoot it. Pepsi will be ice cold! E-mail me at tc_truong72@yahoo.com and I'll give you my cell and the address where I park the 914 at. It's in East San Jose, by Eastridge Mall. Yup, it's a Chalon body kit! I bought this car a little over a year ago w/ the kit and hard labor already done. And good thing is now a '74 DOES NOT require SMOG in CA so hence I was thinking of carbs. timecop369 |
sj914 |
Nov 25 2003, 04:46 PM
Near Eastridge. I thought I was the only one near the Eastside with a 914.
ps. Did you have to get it smoged when you first got it. Mines a '74 also and it I still haven't gone to the DMV to change the name on the pink slip. |
Brad Roberts |
Nov 25 2003, 04:50 PM
Oh.. we forgot to "welcome" you to the BBS. (IMG:style_emoticons/default/clap56.gif)
You can ask anything you want... B |
Mark Henry |
Keep the FI if you can.
If you are sold on the carbs and plan on pumping it up in the future get the 44 Webers. |
Nov 25 2003, 04:51 PM
Brad really needs to charge more for a "house call"
I Think a Case of cold ones at least.... Fix the fuel pump relay.... Brad will set you straight. Rich |
Brad Roberts |
Nov 25 2003, 04:57 PM
Ok. 100$
B |
timecop369 |
Nov 25 2003, 05:06 PM
Thanks for welcoming me GUYS!
Wow... looks like a unanimous vote on keeping the FI. Ok... I will probably stick with that then if I (Brad) can get it fixed... Bascially... I don't know squat about 914s. Yah... I was gonna put a six-pack of Corona's w/ the Pepsi in the cooler. (IMG:style_emoticons/default/smile.gif) Also, I had to get it smoged when I first got it in 2002. Check this site out to see if yours needs smog: http://www.smogtips.com/need_inspection.html or http://www.dmv.ca.gov/vr/smogfaq.htm Thanks Again! timecop369 |
Lo-Fi Version | Time is now: 9th May 2024 - 06:17 AM |
