| ahdoman |
Mar 6 2007, 08:37 AM
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I did an extensive search but this didn't come up...how do I remove the seats?
| sj914 |
Mar 6 2007, 08:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Move the seat forward and you'll see four bolts at the rear of the track. Unbolt those bolts and the seat will tilt forward and out.
You can also release the seats from the track without unbolting. When you slide the seat forward, look under the rail that doesn't have the adjuster and there's a stop you can press on and slide it all the way off. |
| G e o r g e |
Mar 6 2007, 09:50 AM
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None
or (IMG:style_emoticons/default/sawzall-smiley.gif) works to (IMG:style_emoticons/default/biggrin.gif) |
| sj914 |
Mar 6 2007, 10:06 AM
(IMG:style_emoticons/default/agree.gif) or (IMG:style_emoticons/default/sawzall-smiley.gif) works to (IMG:style_emoticons/default/biggrin.gif) Thats exactly what I had to do on the passenger seat. Destroyed the whole thing seat and all. Some how coins were lodged in between the tracks and couldn't get them out no matter what I did. So out came the cutoff tools and some medievel butchering of the seat. |
| dr914@autoatlanta.com |
Mar 6 2007, 10:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,250 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The "tech tips 700" says to slide the seat all of the way forward until is stops. then reach under the outboard bolster and feel for the tension spring clip under the track and lift up on it (you will have to slide the seat back just a bit) then while holding up the tension clip and the loop slide the seat completely out of the car. No need to unbolt anything!!!!!
| Aaron Cox |
Mar 6 2007, 10:47 AM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
The "tech tips 700" says to slide the seat all of the way forward until is stops. then reach under the outboard bolster and feel for the tension spring clip under the track and lift up on it (you will have to slide the seat back just a bit) then while holding up the tension clip and the loop slide the seat completely out of the car. No need to unbolt anything!!!!! thats how i do them... |
| tdgray |
Mar 6 2007, 12:00 PM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
The "tech tips 700" says to slide the seat all of the way forward until is stops. then reach under the outboard bolster and feel for the tension spring clip under the track and lift up on it (you will have to slide the seat back just a bit) then while holding up the tension clip and the loop slide the seat completely out of the car. No need to unbolt anything!!!!! thats how i do them... That's because your special AA (IMG:style_emoticons/default/huh.gif) |
| Rusty |
Mar 8 2007, 04:03 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,995 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States
That seems to be the method I use, too. But I've noticed that after many years, those seat tracks are pretty gummed up.
I have a big waxy stick (like zipper lubricant) that I use after I clean up the tracks. It makes everything slide nicely, and isn't as messy as grease. |
| markb |
Mar 8 2007, 08:37 AM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Something like door ease?
Lo-Fi Version | Time is now: 2nd November 2026 - 04:09 AM |
