How to help! |
How to help! |
1bad914 |
Mar 9 2007, 08:16 AM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
The PO of my car took it for a drive without tightening the lug bolts on the rear, he dorked up the bolts and the threads, I have a spare rear swingarm, but I cannot figure out how to get the hub off, I feel kind of stupid asking, but sometimes your brain locks...need beer! (IMG:style_emoticons/default/beer3.gif) In the pic it is the part that the bolts thread into. Would I be better off replacing the entire arm?
Attached image(s) |
Joe Bob |
Mar 9 2007, 10:36 AM
Flip it over....you'll see the wheel bearing and the other end of the hub.....use either a press or a suitable tool to drive both of them out.....
1bad914 |
Mar 9 2007, 11:22 AM
I went back out and looked at the damage that the PO had done. Two of the bolts were in normally, the other two were partialy in and cocked. About 1/2 of the threads on the bad holes were good, I tapped those holes from the back side and cleaned the other holes out. Once I was done all four went in by hand and torqued down just fine. Man I love it when a bad things ends up easy to repair, it does not happen often! (IMG:style_emoticons/default/beer.gif)
Crazyhippy |
Mar 9 2007, 08:10 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Keep an eye on those lug bolts...
Lo-Fi Version | Time is now: 20th May 2024 - 10:30 AM |
