I'm stumped., /6 cooling fan trivia. |
Series9 |
Mar 9 2007, 07:16 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Slits sent me a fan for Waide's engine and it doesn't fit inside the housing.
As far as I'm aware, there are only two sizes: 245mm and 226mm ('78-'79 only) I have a 245mm housing. This fan appears to measure 250mm, but I'm unaware of anything over 245mm ever being produced. All of the 245mm (early, late and 5-blade) are interchangable. Ron sent an early style 11-blade. It should fit. Liz's early 11-blade does fit. Anyone? Attached image(s) |
sixnotfour |
Mar 9 2007, 07:19 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
really early sandcast alum ring fan you have there .
sixnotfour |
cut it down in a lathe .
sixnotfour |
Mar 9 2007, 07:20 PM
unless Slits has the alum. ring then he should sell as a pair.
Series9 |
Mar 9 2007, 07:25 PM
I was hoping it was a part off of 114.
Slits could eBay it for $$$$. I did notice the casting looked rough, but why can't I find ANY reference to this size fan? |
SLITS |
Mar 9 2007, 07:31 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I have the ring .... he didn't request it.
I didn't sell it .... I just sent what he asked for. Now, if the fan was in an engine fire would it swell 5 mm? I am headed to the parts stash to get the number off the ring, but as I remember it was 3R. |
Series9 |
Mar 9 2007, 07:41 PM
Hot enough to swell=Hot enough to melt IMO. So I don't think so.
The fans should be magnesium. How can I tell this is aluminum without filing it? I can tell the difference between mag and aluminum when I file it, but otherwise???? |
sixnotfour |
Mar 9 2007, 07:46 PM
255 dia.
245 on top of 255 difference in rings Attached image(s) |
sixnotfour |
Mar 9 2007, 07:55 PM
Fans are mag ,The ring is alum on the .03
Series9 |
Mar 9 2007, 08:32 PM
sww914 |
Mar 9 2007, 09:06 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Hot enough to swell=Hot enough to melt IMO. So I don't think so. The fans should be magnesium. How can I tell this is aluminum without filing it? I can tell the difference between mag and aluminum when I file it, but otherwise???? If you hold a torch to it and it melts, it's aluminum. If it turns into a flare, it's magnesium. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) |
davep |
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I believe there was also a 250mm. Rare though. Great thread here:
http://forums.pelicanparts.com/showthread....threadid=332048 |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:42 AM |
