scottb |
who wants a PEZ?! ![]() ![]() ![]() Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States ![]() |
i'm sure this has been asked before, but where would one place the floor jack to raise the front of the car with the back already up on ramps? need the extra space to move around under there.......
or would it be better to have the front on ramps and the rear up on jack stands? thanks in advance.... (IMG:style_emoticons/default/beerchug.gif) |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
i use a 2x12 to span the torsion bar tubes in the A-Arms when there is enough clearance.
it's been suggested that jacking under one torsion tube would probably be okay too. when i'm lifting the whole car i usually do it side-to-side with a jack peg in the side receiver socket, but i've done it end-to-end too. there will be more clearance up front for spoilers and such if you lift it first, and the back second - the pitching movement really cuts down on the room you've got to work with. it might be easier to ramp the front and jack the back if you've got that option. |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
I drive up on 2x6 pads of wood on all four corners. Then jack the front under the torsion arm front brackets. Put jack stands under the donuts behind the front wheel arches. Go to back lift whole car by transmission (Solid mounts). Both wheels come off ground and put jack stands under suspension consoles. Rock solid
Lo-Fi Version | Time is now: 30th July 2025 - 10:55 PM |
