914 6 vs 911 oil cooler, What do you conversion guys do? |
Red-Beard |
Nov 28 2003, 11:41 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
I have 911 and 914 6 oil coolers. I'm curious what the conversion guys do to make the 911 cooler work? Different oil lines? Modify the cooler?
seanery |
Nov 28 2003, 11:47 AM
scotty |
Nov 28 2003, 02:55 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
That looks interesting...
...I just cut and put in a 90 degreee bend in mine (pointing the other way, if the oil line connects to the blue fitting there) Nice engine! Attached image(s) |
steve@ottosvenice.com |
Nov 28 2003, 04:04 PM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
I have one at my desk. I will take a photo of it. steve
campbellcj |
Nov 28 2003, 04:53 PM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I had Ottos convert a 911 cooler, which is the way a lot of conversion guys go.
seanery |
Nov 28 2003, 05:54 PM
blue fitting is for changing the oil. Oil line connects to the other end.
Nov 28 2003, 06:03 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Red-Beard @ Nov 28 2003, 09:41 AM) I have 911 and 914 6 oil coolers. I'm curious what the conversion guys do to make the 911 cooler work? Different oil lines? Modify the cooler? i assume you're talking about the 90deg corner in the 914/6 line as opposed to the straight line in the 911. we had 911 coolers fitted with a 90deg knee in the past. it worked but it's a tight fit, depending on what size oil-line you want to run. Andy |
scotty |
Nov 28 2003, 06:57 PM
QUOTE blue fitting is for changing the oil. Oil line connects to the other end Slick! So it's kind of a "T" fitting...really cool idea. Beats hell out of splitting the oil line. Next time I've got mine off, I'll have to go that route...again, slick! (IMG:style_emoticons/default/smilie_pokal.gif) |
meursault |
Nov 29 2003, 12:17 AM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
I do kinda like the "t" fitting idea. I tried to go as stock as possible. Sent an early threaded 911 cooler with a bent piece of aluminum pipe and a 914-6 cooler as a model to a a buddy who could weld aluminum. Here's what it ended up like. Nevermind the kinked hose; I hadn't fit everything up properly yet.
Mike D. |
Nov 29 2003, 12:46 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I like the T idea. Mine just has a 90 degree fitting welded to it. I didn't do it, don't know who did, Brad mayby, it just came this way.
-Mike D. Attached image(s) |
Joe Bob |
Nov 29 2003, 10:06 AM
On my 3.0 conversion, I cut an elbow from a preformed radiator hose and use BF hose clamps on each end.
Eric_Shea |
Nov 29 2003, 11:02 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Curious...
When doing a 6 with a GT front cooler would there be any different mod to the cooler or would that be handled with a thermostat in the line? |
Joe Bob |
Nov 29 2003, 11:04 AM
The mod is needed because the line coming off the cooler would hit the trailing arm. The front cooler line can be cut in on the passenger side and then plumbed along the passenger rocker panel or under neath or thru the body for the front mounted GT cooler....depending on taste.
Brad Roberts |
Nov 29 2003, 11:23 AM
Yep. The Clewitt setup is the way to go if you dont need a bone stock setup.
GPR/Otto's/PP 90% of the part places sell Clewitts setup. B |
Gint |
Nov 29 2003, 09:44 PM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE Brad Roberts Posted on Nov 29 2003, 10:23 AM -------------------------------------------------------------------------------- Yep. The Clewitt setup is the way to go if you dont need a bone stock setup. GPR/Otto's/PP 90% of the part places sell Clewitts setup. Got pics? |
seanery |
Nov 29 2003, 09:48 PM
see pic above.
Gint |
Nov 29 2003, 09:53 PM
QUOTE seanery Posted on Nov 29 2003, 08:48 PM -------------------------------------------------------------------------------- see pic above. Can you be a little more specific? There are 3 different pics in this thread. |
seanery |
Nov 29 2003, 09:55 PM
the one i posted that says "Richard Clewett did mine" LOL!
Gint |
Nov 29 2003, 09:57 PM
D'oh! Caught me not givin 100% attention again.
Lo-Fi Version | Time is now: 9th May 2024 - 04:06 AM |
