Let's try one more time, I need parts badly |
So.Cal.914 |
May 11 2007, 02:30 PM
Engine mount tweaked so here goes: I need these parts: *Bracket that bolts to body to accept engine mount bolt and nut *Bolt that connects presumably bent (tweaked) engine bar to body *Engine bar that holds engine Due to un-forseen circumstances, I hit a muffler going 75mph. I need these parts quickly as damage worse than I noticed. Thank you It was a good thing you didn't have coolant hoses running exposed under your car. (IMG:style_emoticons/default/cool_shades.gif) |
TravisNeff |
May 11 2007, 02:37 PM
You can bend the engine mount/bar back straight. put the bent end in a vice, grab the opposite side and bend away. |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:25 AM |
