| Heckler |
Mar 22 2007, 01:48 AM
Newbie ![]() Group: Members Posts: 46 Joined: 19-February 07 From: Los Angeles, CA. Member No.: 7,549 |
Being 6'1", the stock wheel doesn't leave me much room to shift/steer, so I'm considering a smaller steering wheel... I know that I'll probably lose sight of portions of the gauges (I can't see parts of them now), I'm just trying to figure out how much smaller to go (which will be partially driven by styles and availability).
Stock is 380mm, and most of the after-market ones are 350mm; but, I've also found some at 320mm, 300mm, and 280mm. I recognize that the smaller you go, the more effort that will be required to steer... Thoughts/Suggestions? How small do I need to go to get the shifting/steering room I need? Thanks! |
| tomamafone |
Mar 22 2007, 03:04 AM
There's no "I" in Teener ![]() ![]() Group: Members Posts: 109 Joined: 7-January 05 From: Hollywood, CA Member No.: 3,414 |
350 is what you want. i'm 6'2'' and it gives you a nice ammount of leg room and plenty of arm work when you're going slow. thats just over an inch smaller than stock. a lot of guys like the momo prototipo wheel for period correctness,
http://www.pelicanparts.com/catalog/shopca..._mowhel_pg1.htm i prefer the monte carlo for feel http://www.pelicanparts.com/catalog/shopca..._mowhel_pg3.htm |
| Heckler |
Mar 22 2007, 06:25 PM
My height is split about 50/50 (32" inseam), I just find that I can't get my right leg out of the way when shifting in particular and it's even worse if I'm trying to steer...
I've checked the Momo site and the majority of their wheels are 350mm. The Commando, Commando R, Millenium, Millenium Evo, Jet, Race, Tuner and Monte Carlo come in 320mm and the "Team" comes in 300mm and 280mm. At first I was thinking the 300mm Team, but once I get the 205/55/16s on the Pack Racing wheels, that'll probably be a little rough at slow speeds... I also found this "Luisi" wheel on eBay, any body heard of them?: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...2400&rd=1,1 Thanks! |
| tomamafone |
Mar 22 2007, 06:36 PM
find someone with a 350mm and then drive it. you'll be surprised how much smaller it is. trust me on this.
| Heckler |
Mar 22 2007, 08:15 PM
find someone with a 350mm and then drive it. you'll be surprised how much smaller it is. trust me on this. You volunteering your car? (kidding) So your Monte Carlo is a 350mm (since they're also available in 320mm)? You perfer it over the Prototipo for ?feel?, can you explain? Thicker/thinner wheel, smooth leather vs suede, etc...? Thanks! |
| Aaron Cox |
Mar 22 2007, 08:20 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
im 6-2, and run a 350mm prototipo. feels great. easy shifting/steering. knees get under it just fine.....
| eg914 |
Mar 23 2007, 12:37 AM
Member ![]() ![]() Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
I am also 6-2. I have a Momo Prototipo, 350mm. It blocks the speedo from about 65 to aobut 90. Blocks the low end of the gas gauge. The top of the tach is blocked by the hood over the gauges, not by the wheel. The car had a smaller wheel when I bought it, and it took a lot more effort to steer. The 350mm size is great, and is not in the way when getting in and out.
| tomamafone |
Mar 23 2007, 05:19 AM
find someone with a 350mm and then drive it. you'll be surprised how much smaller it is. trust me on this. You volunteering your car? (kidding) So your Monte Carlo is a 350mm (since they're also available in 320mm)? You perfer it over the Prototipo for ?feel?, can you explain? Thicker/thinner wheel, smooth leather vs suede, etc...? Thanks! sure you can come drive it. be careful though. sera's my baby. the prototipo is more round and has a corner where the wheel meets the spoke. the monte carlo is wider front to back and thinner side to side and transitions ergonomically into the spoke. the prototipo is suede and the monte is a soft leather. come check mine out if you'd like. its one of the more important things to get just the way you want it. |
| JamesBernard |
Mar 24 2007, 02:05 AM
Member ![]() ![]() Group: Members Posts: 52 Joined: 8-February 07 From: Tigard, OR Member No.: 7,513 |
I want to find one of the old classic Momo steering wheels, from the 70's.
I've seen a few on ebay but i didnt bid because i wasnt sure how easy they were to come by. I like the thicker leather feel, kind of like the monte, but round like the protipo. |
| johannes |
Mar 24 2007, 05:20 AM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,093 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Mittelmotor in Germany also made some stock looking 360 mm wheels.
They aren't cheap ( 499 Euros) ... http://www.mittelmotor.de/deutsch/neuheiten/lenkrad.html |
| Gustl |
Mar 24 2007, 07:12 AM
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,207 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
Mittelmotor in Germany also made some stock looking 360 mm wheels. They aren't cheap ( 499 Euros) ... but this one is available with a 30 mm (about 1.2 inches) "higher" hub - and that will bring additional space between steering wheel and shifter I've bought one and will get it installed for the coming season (IMG:style_emoticons/default/driving.gif) btw - I'm abbout 6-4 at 258 lb (if I converted correctly ... the metric system ...) (IMG:style_emoticons/default/wavey.gif) Gustl |
Lo-Fi Version | Time is now: 16th September 2026 - 07:31 PM |
