1.8 rebuild, 1974 Porsche 914 1.8 rebuild |
orange914 |
Mar 25 2007, 01:05 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
QUOTE On mine I used D-jet so I couldnt specifically say other than its my understanding that it should be EASIER to tune a slightly modded L-jet motor. Basicaly Fuel presure, Flapper gear and fine idle screw (I'm sure someone will step up and tell me I wrong and full of (IMG:style_emoticons/default/stromberg.gif) (IMG:style_emoticons/default/biggrin.gif) ) I bought a set of KB 96's and Hasteing rings from Raby (with the correct Pin height for the 1.7/1.8) the only other thing I did to mine was rebuild a set of 2.0 heads slap on the 2.0 FI 2.0 SS HE's and a Bursch Exhaust modded for a WB02 sensor (IMG:style_emoticons/default/thumb3d.gif) Geoff used his LM1 to tune the MPS and its a kick (IMG:style_emoticons/default/driving.gif) is the only difference with 1.7 and 2.0 d-jet f.i. system in the computor programming? if you where to put a hotter cam or increase c.c.'s on a 1.7 engine with D-jet (or in this case a hot 1.8 |
Lo-Fi Version | Time is now: 7th June 2024 - 06:39 PM |
