my heat exchangers are shot, do I need them....?? |
DrifterJay |
Nov 29 2003, 05:17 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
Ok, I dropped my motor last night..nightmare, well my exhaust is garbage basically, the muffler has one nasty crack/hole in it and the tin for the exhangers is rusted through, and basically serves no purpose. I am not running heat, so could I cut it off and just run the headers? Or are they there to dissipate heat also? If I can toss them, what other of the heat ducting slash air flow crap can I toss? I will be using this exhaust/muffler for a short time till my bonus comes in...then Tangerine header and webcam 86a....Thank you, any help would be greatly appreciated (IMG:style_emoticons/default/smile.gif)
Qarl |
Nov 29 2003, 05:29 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Run the headers.
You can dump the heater flapper boxes and flexible piping that connect from the exchangers to lower corners of the engine compartment (underneath the battery tray and the opposite side. You can ditch the blower motor in the engine compartment and the hose(s) that connect to the heat ducts in the corners on top of the engine. Tangeringe headers....mmmmm.... nice! |
DrifterJay |
Nov 29 2003, 05:33 PM
thanx kellzey already cutting...
Lo-Fi Version | Time is now: 9th May 2024 - 05:26 AM |
