Which 901s had the "GB" mainshaft?, Need some technical expertise from the club! |
race914 |
Mar 24 2007, 09:18 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Need some help from the club with the technical data to identify if a 901 transaxle has a F, GA, or GB mainshaft.
This is a question from a current classified ad I'm fine tuning my gearset for Laguna Seca, and the F second gear mainshaft in my 73 914-4 901 is too low for turn 11 so I'm looking for a GB mainshaft. I know I could go to a 904 mainshaft which would allow me to switch out 2nd gears, but that is alot more $$$ Thanks in advance for your replies From the technical expertise on this site, I know someone probably has this memorized! (IMG:style_emoticons/default/pray.gif) Thanks again, Greg |
davep |
Mar 24 2007, 11:27 AM
http://members.rennlist.com/chuxter/901&915ratios.htm
Does not indicate the GB was an actual mainshaft combo. That is, I would expect from this chart that GB was a ratio for the 914 mainshaft only. When obtaining a mainshaft (not 904), you need to get the mating 2nd gear with it. |
Martin Baker |
Mar 24 2007, 11:36 AM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
Sorry to have caused all this trouble Greg!
And allow me to THANK YOU for being my Instructor at Laguna Seca for my first time there. I learned allot in a short time! |
Aaron Cox |
Mar 24 2007, 12:30 PM
http://members.rennlist.com/chuxter/901&915ratios.htm Does not indicate the GB was an actual mainshaft combo. That is, I would expect from this chart that GB was a ratio for the 914 mainshaft only. When obtaining a mainshaft (not 904), you need to get the mating 2nd gear with it. second gear ratios i know of F, GA mainshafts H,HA,HB,I second gears you could put in a 4 speed or on a 904 shaft |
bondo |
Mar 24 2007, 12:34 PM
I've got an A mainshaft if you want to go 4 speed.
Aaron Cox |
Mar 24 2007, 12:35 PM
great paperweights, you need any more? (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/chairfall.gif)
Mar 24 2007, 03:57 PM
I thought Chris Foley figured out a way to remove the 2nd gear..
It could just be placing the shaft in a lathe and removing it, and then I think, could be wrong...that you can then put on the other gears mentioned..not sure about any of this...but I know Chris knows.. Rich |
race914 |
Mar 24 2007, 09:08 PM
Sorry to have caused all this trouble Greg! And allow me to THANK YOU for being my Instructor at Laguna Seca for my first time there. I learned allot in a short time! This is all Martin's fault. I was happy 'bogging' out of turn 11 at laguna at 3200 rpm with my Ka 3rd gear until I rode in Martin's car! Boy does his car LAUNCH out of turn 11 in 2nd with his "airport gearset"! (IMG:style_emoticons/default/drooley.gif) Thanks to everyone for your replys. I'll update this thread with what I find and what I end up with... |
race914 |
Mar 24 2007, 09:26 PM
http://members.rennlist.com/chuxter/901&915ratios.htm Does not indicate the GB was an actual mainshaft combo. That is, I would expect from this chart that GB was a ratio for the 914 mainshaft only. When obtaining a mainshaft (not 904), you need to get the mating 2nd gear with it. second gear ratios i know of F, GA mainshafts H,HA,HB,I second gears you could put in a 4 speed or on a 904 shaft Hi Aaron, The H 2nd gear looks awesome on the gear calculator. I talked with the Carquip.com guys and they do have repro 904 mainshafts and an H gear, but it's big $$$. They sell the GB mainshaft (which after this thread I'm not sure what ratio 2nd it really is...) for $400, but they don't currentlyl have any. Thanks for the ratio info. Hope to see you at an event this year if I ever wander down south! Greg |
Aaron Cox |
Mar 24 2007, 09:28 PM
I thought Chris Foley figured out a way to remove the 2nd gear.. It could just be placing the shaft in a lathe and removing it, and then I think, could be wrong...that you can then put on the other gears mentioned..not sure about any of this...but I know Chris knows.. Rich i think he cut off an F second and welded on an I gear. i guess you could cut it and spline ala a 904 shaft |
bondo |
Mar 25 2007, 01:02 AM
great paperweights, you need any more? (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/chairfall.gif) Kinda long for a paperweight.. but it makes a great clutch alignment tool. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:23 PM |
