Replacing engine mount bar |
krazykonrad |
Mar 24 2007, 10:30 AM
Senior Member Group: Members Posts: 1,126 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Is replacing the engine mount bar difficult or are there any hidden pitfalls? I have a bus bar on mine and the engine/ tranny is not quite lined up perfectly.
Thanks, Konrad (IMG:style_emoticons/default/beer.gif) |
rhodyguy |
Mar 24 2007, 11:22 AM
pretty simple. back of car in the air, support the front of the engine, remove the 2 inboard fasteners (on the middle bottom of the bar), liberally spray the outboard fasteners with a GOOD penetrant, and take them off. replace the bar with the one for the correct application.
k |
Mar 24 2007, 11:24 AM
pretty simple. back of car in the air, support the front of the engine, remove the 2 inboard fasteners (on the middle bottom of the bar), liberally spray the outboard fasteners with a GOOD penetrant, and take them off. replace the bar with the one for the correct application. k Add one point...hold up engine while working. |
Cap'n Krusty |
Mar 24 2007, 11:42 AM
...............and remember you have to replace the bracket(s) bolted to the case ........ The Cap'n
rhodyguy |
Mar 24 2007, 11:51 AM
pretty simple. back of car in the air, support the front of the engine, remove the 2 inboard fasteners (on the middle bottom of the bar), liberally spray the outboard fasteners with a GOOD penetrant, and take them off. replace the bar with the one for the correct application. k |
krazykonrad |
Mar 24 2007, 08:48 PM
Thanks for the advice! should I support the front of the engine or the whole thing? Where should I put the jack? Sorry for all the dumb questions, I just want to keep from ending up squished, or worse yet, screwing something up.
THanks again, Konrad |
Lo-Fi Version | Time is now: 17th May 2024 - 06:25 PM |
