Front end Shimmy!, Need a good used Rack |
Solo914 |
Mar 29 2007, 10:17 PM
Member Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None |
Well,
I have been driving around with the front end shimmying for awhile now and I thought it was a tire out of balance, then it started getting worse. I had the wheels rebalanced and had another set of tires put on(i had another set) and it is still there. A post I read about steering racks wearing out got me thinking and I checked mine... it is very very sloppy. So, Does anyone have a good used steering rack they are looking to get rid of..... oh.... and I am 914 owner which means that by default I am cheap......just like you.. and you and you... and especially you. Thanks in advance guys!! (IMG:style_emoticons/default/biggrin.gif) Kyle email me kyle(dot)freiheit (at) gmail.com |
914-8 |
Mar 29 2007, 10:19 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
if you're really cheap, you should do more to figure out what the problem is, rather than just buying and replacing random parts which have a good chance of not being the problem.
bd1308 |
Mar 29 2007, 10:34 PM
My ball joints went out
I had shimmies really bad what wheels do you have? Therory is that the aftermarket wheels centers arent exactly centre, and dont really work well with the tire balancers at Big O |
Solo914 |
Mar 29 2007, 11:05 PM
My ball joints went out I had shimmies really bad what wheels do you have? Therory is that the aftermarket wheels centers arent exactly centre, and dont really work well with the tire balancers at Big O you are probably half right, I like the look of empis but they are far from perfect Alright so I didn't post everything about what I have done. I have slowly been rebuilding this car and I have checked everything out. The whole front end has been rebuilt, poly bushings, koni singles, new upper strut bushings etc. I was replacing the front calipers(different issue, leaky calipers, THANKS ERIC S!) and finally had a chance to get it up in the air. The front ball joints are fine but when I checked the play in the front left tie rod it had play up and down, inside and out and the right side was worse. I never throw money at problems and was even thinking of pciking up some bronze and rebushing it myself. I still may go this route after my new to me(used) rack wears out. Thanks guys. Kyle |
sww914 |
Mar 29 2007, 11:11 PM
GPR should have a pile of good used racks, he's parted out enough cars.
woobn8r |
Mar 30 2007, 08:17 AM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
You may wish to check your front rotors also...
brp914 |
Mar 30 2007, 10:55 AM
Unregistered |
I tried, but gave up on the idea of rebuilding the rack. No internal parts are available from porsche. There is a ball bearing and a needle bearing inside which surprisingly are commonly available, but bushings, pressure block, and shims - you're on your own. I threw in the towel and got a rblt from porsche for ~$525. Yeah, alot, but it is perfecto, and going in with brand new bil struts/s-calipers/turbo tie rods/needle bearings.
here's the associated carnage of that effort: Attached image(s) |
Joe Ricard |
Mar 30 2007, 11:24 AM
I got what you need make me an offer. No slop and only slight slack in the pinion.
Pm me for details. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:07 AM |
