How much Curil K2 goop goes on case halves?, ...and a couple other questions... |
mike373 |
Mar 30 2007, 02:21 PM
Member Group: Members Posts: 198 Joined: 3-August 05 From: san diego, ca Member No.: 4,536 |
Ok.... getting to the stage of actually putting stuff back together. How much Curil goop goes on the case halves.... and what should it be applied with? Also.... What should I use to seal the threads on the cylinder studs when I put them back in?? I have Loctite 565 PST for the case plugs... is that the same as standard Loctite 565??? Or did I buy the wrong stuff?
Thanks, Mike |
Lo-Fi Version | Time is now: 17th May 2024 - 02:49 AM |
